Home > Maintenance & Mods (L322) > How could the garage have messed this repair up?
kooky_guy
Vehicle failed mot on the following:
Repair immediately (major defects):
Offside Rear Suspension arm ball joint excessively worn upper balljoint/bush (5.3.4 (a) (i))
Bit surprised as it's only done 2k miles since the last test with no advisory then and it's had a service in between. Anyway, against my better judgement I got them to fix it (non specialist).
Got it back and now the steering wheel is offset although it didn't seem to pull. Thought I'd get them to look at it again when we got back from holiday. Away now on holiday and it's been handling a bit weirdly and getting worse and occasionally feels like something is loose underneath.
I'm not sure which joint this is, but anyone got any thoughts before I take it back to them? 2010 4.4 TDV8 Vogue SE
Post #640108 18th Aug 2022 10:16pm
DrRob
Personally, I would not take it back to them as they could make things even worse. Get it to Glenrands. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #640119 19th Aug 2022 7:35am
dingg1
Whatever they've done on the rear will not have changed the steering geometry, something is awry.....
Post #640124 19th Aug 2022 8:14am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Something doesn't sound right here. No advisory on last MOT, What service was done since then & is it the same garage replacing the joint as carried out the MOT?. Shocked
I would want to know exactly what they have done & possible let a good Indy look at it from now on.
Post #640125 19th Aug 2022 8:34am
kooky_guy
This is exactly what I thought. It was the same garage that did the test but they do have an excellent reputation locally. I'm just wondering what they could have done wrong due to lack of experience perhaps.
Is this one of those joints that needs to be tightened with weight on the wheels? 2010 4.4 TDV8 Vogue SE
Post #640133 19th Aug 2022 9:07am
kooky_guy
I'm struggling to find a good indy locally. My usual is just too expensive now and cooked up the last job they did on it. 2010 4.4 TDV8 Vogue SE
Post #640134 19th Aug 2022 9:09am
kooky_guy
This is the joint they've replaced. 2010 4.4 TDV8 Vogue SE
Post #640138 19th Aug 2022 9:49am
Weegie
Strange that the steering wheel is out of alignment if they have only been working on the rear. A problem at the rear can affect steering and handling.
You need to find out from them exactly what was done. John
GAP iiD BT-Sold
Post #640140 19th Aug 2022 10:04am
Highroller
When you say that the steering wheel is out of alignment. I take it that you mean you're having more steering wheel input to maintain the correct steering angle.
As Weegie has mentioned. An issue with the rear geometry could effect this.
Let us know what they find or say, once you have taken it back to them. Thumbs Up
Post #640143 19th Aug 2022 10:16am
JavaBlack
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
SC486 adjusts the rear toe.
Post #640146 19th Aug 2022 11:02am
DrRob
My recommendation on local specialist given in previous post. Plus site sponsor and loan cars. I can only advise based on my onw personal experiences. I won't go anywhere else now and I've tried a few round this neck of the woods.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640153 19th Aug 2022 11:14am
kooky_guy
Not sure why my photo didn't seem to show. Can anyone else see it?
As far as the steering wheel goes, when driving straight, the wheel is now at about 10 past 8. Its not pulling, its just not straight any more.
I'd love to take it to your specialist DrRob as they sound great but it's too far for me really. Anyone used Bagshot LDR? 2010 4.4 TDV8 Vogue SE
Post #640166 19th Aug 2022 11:55am
Weegie
Can you get full lock left and right? John
GAP iiD BT-Sold
Post #640167 19th Aug 2022 11:57am
kooky_guy
Yes, steering feels fine apart from a strange feeling from the rear. I thought I was imagining it but it's quite noticeable on these twisty country lanes. 2010 4.4 TDV8 Vogue SE
Post #640169 19th Aug 2022 12:04pm
Highroller
Photo clearly shows the new offset bolt replaced.
This controls the Rear wheel camber & as previously mentioned requires wheel alignment once replaced.
Once the geometry has been setup correctly it should drive much better Thumbs Up
Post #640174 19th Aug 2022 12:30pm
