![]() | Home > Maintenance & Mods (L322) > How could the garage have messed this repair up? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1393 ![]() ![]() |
But any work on the rear will not cause any offset on the steering wheel. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3309 ![]() ![]() ![]() |
That bush requires the alignment to be set up after it's been replaced.
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Thanks all, really appreciate the replies.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
Always remember Glenrands aren't far from Sandhurst, even if you need a phone call for some advice. 2015 Range Rover Autobiography 4.4 SDV8 |
Glenrands do alignment work AFAIK. Mine's just failed for the same reason and it needs a new bolt as the original one is seized in the bushing so they have to cut it out. Glenrands looked at it a few weeks ago and said they needed replacing but didn't have time to do the work due to them expecting to have to cut out the bolts x4 so I'm lucky only one has failed. AFAIK these bolts only adjust the camber ? 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
Had results several times using a 3/4 inch drive HGV rattle gun, it either shakes them loose or sheers the bolt clean off and then no need to cut them, punch them out with an air chisel... |
They threw everything at it this afternoon but didn't want to risk shearing it off without having a replacement. 2012 TDV8 Vogue (L322) |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Is it me or is that mega rust for a 2010 my 07 is nothing like that - if you haven’t already I’d get your cill covers off and check them before you get a nasty surprise later down the line - I’d probably check the rear subframe too Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
It does seem a bit crusty but I think it looks worse in the photos than it actually is. I was wondering if I could clean it up a bit.
Fair enough if you’ve checked hopefully surface rust.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
I think they're wrong to be honest. It's part of the adjustment for the alignment. Also, check they can lock it into Tight Tolerance Mode. If not, walk away and take it to somewhere else...... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Yes and they do it properly e.g. Tight Tolerance Mode, Hunter 4 wheel laser kit and if any bolts are seized they will insist on replacement so it can be adjusted correctly. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
