Home > Maintenance & Mods (L322) > Mood / Ambient lighting
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I had the HVAC sides off today to replace a clicking blend motor and had an idea to fix ElectroLuminecence wire to the edge of the panel to see what it looked like. I had 2x 1mtr lengths in a draw so with a hot glue gun fixed the strip where required and pushed the retaining edge in between the wood trim and edge. Easily connected to the fusebox in the glovebox with an add-a-fuse on an ignition switched location. What do you think, it can just as easily be removed with no trace, I will leave it for the time being. Only a couple of pounds per side and adds a subtle blue glow to the footwell
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #640275 20th Aug 2022 11:18am
The jury is out on the light but tell me more about your mats... Thumbs Up Pete
-Click here for Thread-
Post #640279 20th Aug 2022 12:12pm
wayneg
Had them custom-made via Aliexpress. Diamond quiled, lots of colourways. they are great and cheap enough. seem to be very durable and easy to clean. there are loads of sellers, chose one who will add a logo.. about 40 pounds front and back. I will post a picture tomorrow ( Night in OZ now ) if you are interested.. https://www.aliexpress.com/item/1005003565...0269100_15 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #640281 20th Aug 2022 12:23pm
garyRR
For something a little more subtle, this is the ambient lighting I fitted to my FF, which matches in hue and colour with the 2020-> RRs (i eventually found the matching RGB to set through the app).
https://www.fullfatrr.com/forum/post624201.html#624201
They only come on when the headlights are on (and don't flash when you flash main beam, as they're connected to the tail light fuse). 2015 Range Rover Autobiography 4.4 SDV8
Post #640330 20th Aug 2022 7:13pm
