Home > Maintenance & Mods (L322) > Any instructions on how to adjust bonnet and latches?
garyRR
I've scoured the forum and the workshop manual and can't find the instructions for bonnet and latch (striker) adjustment. The workshop manual seems to just reference it.
I'm clearing up the jobs main dealer didn't do properly following accident damage and one of these is adjusting the bonnet correctly. Incredibly they quality passed the vehicle with missing bolts, a visibly wonky numberplate and still accident damaged splash guards AND the left side bonnet catch isn't even locked when driving along!
And on the right hand side, it's over-adjusted that I almost have to sit on the corner of the bonnet to force it down enough to latch.
Instructions for adjustment would be much appreciated because I don't trust the dealer to do a proper job. 2015 Range Rover Autobiography 4.4 SDV8
Post #640402 21st Aug 2022 5:03pm
There are two rubber stoppers that screw into the top of the slam panel, you use these and the bonnet latches, there is a locknut that you spin down to allow adjustment on the latches, put a spanner through the spring to spin it, then the rubber stoppers give you the height of the bonnet and the catches are then adjusted with a slotted screwdriver in the pointed end so they latch when the bonnet is shut, it's just a matter of adjusting one and see what happens, it doesn't take much to get it sorted once all is lose and easy to move... Thumbs Up Pete
-Click here for Thread-
Post #640403 21st Aug 2022 5:20pm
garyRR
Thank you.
For whatever reason they'd fully extended the plastic foot and the latch on one side and adjusted the other.
All reset, took out the latches, cleaned them up, re-oiled the threads and re-greased the springs and strikers and re-fitted and now both sides are adjusted within 1mm and latching properly Thumbs Up 2015 Range Rover Autobiography 4.4 SDV8
Post #640416 21st Aug 2022 6:47pm
Excellent, it a very satisfying job... Thumbs Up Pete
Post #640421 21st Aug 2022 8:11pm
garyRR
...that main dealer should have done for me!
I wonder if I can charge them £145ph for everything they didn't do. 2015 Range Rover Autobiography 4.4 SDV8
Post #640422 21st Aug 2022 8:49pm
DrRob
Main dealers. A disgrace.
Bunch of Censored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640423 21st Aug 2022 8:56pm
Phoenix
The job would have most likely been SC'd to a bodyshop, usually the one the insurance co. designates, the dealer would just be the customer interface.
Post #640425 21st Aug 2022 9:27pm
garyRR
The bodyshop was the main dealer's bodyshop, part of the firm. 2015 Range Rover Autobiography 4.4 SDV8
Post #640426 21st Aug 2022 9:29pm
Phoenix
Oh, well in that case,
Dealers, grrr.
Post #640427 21st Aug 2022 9:31pm
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
I found I had a weird humming sound at 130km/hcomming from the hood
I found this eventually
cost me 80€ each from lithuania... Big Cry
noise is gone (I did a minor mod on them though) : I filled the front holes with rubber foam so no air would get in them (as I think that's what tore them)
I'll have to make a picture if you're interested.
Cheers
Sylvain "it needs some intelligence to undestand you may not have enough"
Post #641036 27th Aug 2022 9:46am
garyRR
My bonnet latches are all sorted now.
But yes, I also have one of my bonnet seals in that condition also. Will replace it when I see a cheap one on ebay. They're about £70 in the UK, which for a bit of rubber seems expensive. 2015 Range Rover Autobiography 4.4 SDV8
Post #641037 27th Aug 2022 9:49am
ergobyte
I only mentioned them because they are part of the laching efficiency and must be properly compressed to be efficient.
Cheers "it needs some intelligence to undestand you may not have enough"
Post #641038 27th Aug 2022 9:56am
kevinp
This is how I mended mine.
Post #641047 27th Aug 2022 10:43am
