Home > Technical (L322) > Dodgy Starter?
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
garyRR wrote:
Got the battery on a smart charger to see?
HE put a booster pack on it and it fired straight up.
Doesn't rule out the possible resistance issue with the cable obviously but i think for now I'll try a replacement battery. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #640528 22nd Aug 2022 4:43pm
MartinD
New battery ordered from Battery Megastore so hopefully tomorrow she'll be reet! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #640540 22nd Aug 2022 7:05pm
JayGee
AGM battery? Also you will need a special security 5 point torx tool to get the ECU out of the way. 2012 TDV8 Vogue (L322)
Post #640541 22nd Aug 2022 7:09pm
MartinD
Yep Bosch S5 and I have the security bits in a set Smile 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #640542 22nd Aug 2022 7:16pm
garyRR
Also check the alternator is charging properly, and was not the cause of a dead battery.
To get an indicator of this (it's not scientific but will confirm yay or nay), you don't even need to open the bonnet.
With the engine running, get on the stereo:
1. Press the physical 'Home Menu' button
2. Press and hold the top banner on the screen for 5 seconds
3. Press the physical 'Navigation' button and hold until a pin entry screen appears
4. Press 7 5 3 then 'Ok'
5. Select 'Vehicle Signals'
In the top right corner, you'll see 'Battery Voltage'. It should be showing between about 13.5V and 14.5V. 2015 Range Rover Autobiography 4.4 SDV8
Post #640551 22nd Aug 2022 10:23pm
MartinD
That's the first thing I did after he started it - got IID plugged in. Loads of random codes cleared out and then on to Live Data for the battery/voltage. Was sitting around 14 and increased to around 14.3, 14.5 when revving so I think the alt is fine.
Once the new battery is in I'll go for a long cruise and record the data to make sure there's nothing dodgy going on. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #640566 23rd Aug 2022 6:38am
