![]() | Home > In Car Electronics (L322) > DPS=ECU |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7988 ![]() ![]() ![]() |
I assume the ECU in the DSP, but happy to be corrected. The DSP is an active crossover, the amp is in the BM54 radio unit.
Googs Member Since: 19 May 2022 Location: Tassie Posts: 159 ![]() ![]() |
Yes the DSP is in white sometimes, as I say the amp or wiring seem to have a intermittent fault cause I canāt seem to find which part is a fault!
It will need to identify on the iBus, to say itās there, so in white on the screen. If thatās not done it will never work.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I had similar problems initially and eventually traced it to bad connections within one of the two plugs on the dsp that serve the speakers, canāt remember which one it was though.
nicedayforit;
I donāt know if you get much rain where you are but is there any chance that water has got into the car.
The weather in Tasmania is much like your weather (a few years ago anyway) rain one day windy the next and sunny the day after. š
The only other thing I can think of is when l got my car originally and had problems with the sound I found a small Connects2 module down behind the tv module. I understand this was some type of switch that allowed use of the original now redundant telephone installed in the car. This module was badly corroded so l bypassed it and threw it away, never use the telephone anyway.
Thanks, ill have a look for the connects2 thingy when its light outside.
Yes for the big black plug, theyāve been known to suffer corrosion.
The only thing that would be nice to know is what color are the wires on the connect2 thingy?
From memory the connect 2 unit was a 60mmx60mmx 12mm or thereabouts and was grey plastic with a Connects 2 logo on it.
Yeah, that wonāt be factory fit.
Thank you very much....this is one reason why these Forums are so good, to help other from all places in the globe.
