![]() | Home > Technical (L322) > Forced DPF Regeneration using Gap iid. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8706 ![]() ![]() ![]() |
Cheers Mike, just concerned with what may happen if at around 30,000 miles (from the amount of regens) someone has gutted the DPF and I force a regen...!!
After a moment of reflection, I'm with you on that one ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3846 ![]() ![]() ![]() |
Pete,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Post some pictures of your DPF |
Thanks Mike and Rob, I will have a look at it next week when it gets on a ramp, not sure if I will post any "evidence" on here though... |
Fair point |
Yep, it just goes to show how a diagnostic tool can be a two edge sword... Plug it in and maybe you will learn more than you want to...!!!
Good plan. Use the IID when you need it not when you think you need it |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1776 ![]() ![]() ![]() |
…………. V6 Vogue - “Less is More” - less to go wrong! |
Zero chance of crankshaft failure on the V8 2012 TDV8 Vogue (L322) |
I am putting the IID down and walking away..........!!!!!!!!! |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Even so I think it good to know that the gap tool update has been made available now thanks to these postings. New to range rover’s and after a few replacements of sensors, rightly or not, it gives hope to a new owner. I learnt that a decent run will sort things out. Had mine for 5 years now but needed to take such a drive three weeks ago after the dreaded yellow warning! |
