Home > Technical (L322) > Forced DPF Regeneration using Gap iid. |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Gutted DPF's will set a DTC due to lack of differential pressure, you either need to have the ECM software modified or introduce a downstream pressure drop within acceptable limits (2-5 Hpa is a good differential for a low DPF load). Ash load is calculated, not measured. |
27th Aug 2022 11:24pm |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 167 |
I’ve been chasing some error codes for a while and whilst checking some sensors, noticed the DPF remaining volume states 0 pints? What does this mean? Does it mean it’s full or is it empty? Do I need to do anything? I occasionally get a restricted performance error along with P050E, P041C and P040D codes with bank1 exhaust bank 212F/100C temps (failed??). Any thoughts?? |
10th Sep 2022 12:34pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3680 |
Sorry, no idea why, but DPF remaining volume always reads 0.
10th Sep 2022 1:18pm |
Thanks Baltic Blue….👍 |
11th Sep 2022 9:16pm |
