![]() | Home > Technical (L322) > Cable routing |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
Just wondered… if I wanted to pass a bunch of cables through from the cabin to the engine bay, is there a ready made route I can use?
Thanks Gary. Will do. Tym
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Yep. I ran the coax and power cable for my UHF radio through that grommet. I snaked a well lubed piece of 1.6mm welding rod through first and used it to pull through the coax and figure-8 power cable. I can't remember if I had to remove the end piece of the dash that holds the cup holder to get access to the welding rod after it came through or just the end closing panel. It was some years ago. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
Thanks p38
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Just drop the glove box down and open the bonnet and you should find a route.
Removed Tym
Thanks Gary. You seem to have the same set up as I do. I found the huge boot that, worst comes to worst, I can cut and silicone around the wires, but can’t get to the cabin side.
Post duplicated. Can’t find delete! Tym
