Home > Maintenance & Mods (L405) > Trailer Plug wiring
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Trailer Plug wiring
Morning all,
Sorry for so many posts lately - getting a few things sorted with the new car.
I have a small trailer that I used on my previous Range Rover which had a 7 pin connector. The new One however has more 'holes' to fill Shocked
I assume its thw newer Euro style 13 pin one I need now - I clearly won't have 13 wires to connect up but am I to assume the colour coding is the same and I just miss out the ones I dont have..??
Seems the replacement updated plug is only about £8 from our favourite rain forest shop....
Alternatively.... have folks just used an adaptor like this...?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #641292 29th Aug 2022 9:16am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I use the adapter in the link, works fine for occasional use.
Post #641295 29th Aug 2022 9:25am
knwatkins
Coincidentally, I picked up one of the adapters yesterday from ECP.
Good quality, made by Maypole and only £3.77. I tried it out on the L405 yesterday and it fits fine.
https://www.eurocarparts.com/p/maypole-ada...551773320? Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #641296 29th Aug 2022 9:36am
CS
Adaptor here too, works fine, much easier than rewiring. Only Range Rovers since 1988
Post #641306 29th Aug 2022 11:20am
Another vote for the adaptor - bought mine from the shop here although that appears to no longer have any stock of anything.
Word of warning though - you will of course need to remember to remove it before trying to retract the tow bar. Mike - MPx
Post #641310 29th Aug 2022 12:17pm
comports
Thank you all for your replies.
Adapter plug ordered from ECP.. Thumbs Up Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #641400 30th Aug 2022 7:36am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Wiring colours should match up just print off the two wiring diagrams and check your existing 7 pin plug colours match. Some trailers use two wiring looms that join in the plug which makes it a little bit harder. I have just rewired the plug on a new (to me) car transporter trailer to avoid having to use an adaptor.
I have an adaptor that I can use but find it isn’t as secure as a 13 pin plug that you screw to lock on. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #641408 30th Aug 2022 8:58am
