![]() | Home > Maintenance & Mods (L322) > 4 short intake hoses! |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 ![]() ![]() ![]() |
So over the weekend I’ve had the reduced performance pop up on the dash and thanks to this forum have found a split intake pipe on the n/s/r of the doughnut I’ll replace all four as there the older style I’ve gathered from other posts.
Thank you for your reply. So I’m best off just getting some straight pipe and cutting 4 55mm pieces then. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2731 ![]() ![]() |
That's what I did at a fraction of the cost of new genuine hoses. |
Pipe arrived today so the weekends job is all set to go. If the weather holds out Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 105 ![]() ![]() ![]() |
@RRV78 Did you buy straight pipe, if so do you have a link?? |
https://www.ebay.co.uk/itm/195144378435?mk...media=COPY
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
I’ve just fitted the Land Rover ones I bought a while back and they seem quite a bit shorter than the old ones - I hope there’s enough grippage. |
@RRV78 Ordered! Many thanks... another wee 'to-do' coming up... |
