Home > General > Does anyone know this car. |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
I think that’s not the rust he was going on about, if you look at the picture of the left hand rear with the door open you can see rust disappearing down behind the sill cover. This is a well known rust trap that no one sees until too late. The only answer would be to get the dealer to remove the sill covers both sides so you can see for your self.
31st Aug 2022 11:43am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Here's my (ex) Orkney TD6 next to my Stornaway TDV8. It's only after reading what you wrote that I realised they are actually slightly different colours.
I guess they're both still pretty grey places, especially in winter. |
31st Aug 2022 4:30pm |
...or the other way round. |
31st Aug 2022 4:31pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1119 |
I made these one piece rubber covers that completely cover the wheel arch lip when the door is shut so no nasty stones can do any more damage.
31st Aug 2022 5:40pm |
paulN186 Member Since: 28 Jun 2022 Location: edinburgh Posts: 39 |
yes this is what i was talking about seems to be on alot of them but not all, I think alot to do with where the car is based, i.e away from salty roads |
1st Sep 2022 12:01am |
beemer5711 Member Since: 01 Aug 2022 Location: Wales Posts: 72 |
Cheers for all the advise, guys.
1st Sep 2022 8:49pm |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
AFAIK you can now get repair panels for the arches.
2nd Sep 2022 8:26am |
when you say underneath, where do you mean?
2nd Sep 2022 12:30pm |
Round the jacking points & suspension mounts - don't forget the door sills. |
2nd Sep 2022 12:39pm |
just realised it was you that scrapped the car due to it...
2nd Sep 2022 12:44pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
Just had mine done. Two new panels but be aware they do not extend all the way down to the sills. Body shop had to fabricate inserts to carry them down. I think, from the photos and the way mine were, that the sills are going to have to be done as well. I can tell you, not a cheap job. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
2nd Sep 2022 2:36pm |
Really? You think the sills will be shot?
2nd Sep 2022 3:01pm |
You need to check. Mine seemed alright but when the covers were removed they weren't. Have a good root around' John
2nd Sep 2022 3:23pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 252 |
FWIW; I discovered minor surface corrosion in exactly that position and around the area of the still cover on my 2012 after I bought it. The sill covers are easy to remove and I treated mine with Hammerite No.1 Rust Beater under the sill cover area. The sills themselves were solid. The car was then under sealed with Dintrinol at Southwest rust proofing in Westbury. I followed up on the visible part of the arch with smooth Hammerite black gloss spray. All done, stopped any rust coming back and the resultant finish is good enough that it can’t be seen unless you are specifically looking for it. And of course it’s all covered when the rear doors are closed. I also fitted continuous wheel arch lip strips; I used parts from a freelander 2; see the advice on YouTube below which also lists the Britpart part numbers. TDV8 4.4 2012 |
3rd Sep 2022 5:58pm |
