Home > Maintenance & Mods (L322) > Did Halfords recommend the wrong Oil???
Clarky4.4tdv8
United Kingdom 2011 Range Rover Vogue 4.4 V8 Adriatic Blue
Vehicle = 4.4 TDV8 2011 VOGUE.
When I entered my Reg Number in Halfords it recommended
MOBIL SUPER 3000 X1 FORMULA
FE 5W-30 OIL
Reading on the Range rover owners book, I am not sure if this Oil is suitable or Not
I am wanting to do my own service, so any help would be really appreciated[/b]
Post #641750 2nd Sep 2022 10:43am
The ACEC numbers in the small print is the thing to follow... It needs to meet these criteria NO MATTER WHAT!
You can find those numbers in your user manual... I won't publish them here as they change between models/ages as there are different DPF's... Thumbs Up
Post #641752 2nd Sep 2022 11:07am
Clarky4.4tdv8
Thanks, I will try and locate them
Post #641755 2nd Sep 2022 11:17am
Baltic Blue
I use Shell AF - L in my 2011 4.4 tdV8, you can see the specifications….
Post #641767 2nd Sep 2022 11:54am
DrRob
Has to be WSS-M2C934-B spec for my 2011 4.4 TDV8 fitted with a DPF.
I use Morris of Shrewsbury version on mine that meets this spec.
MULTIVIS ADT C1 5W-30
SYNTHETIC TECHNOLOGY - LOW SAPS
https://www.morrislubricants.co.uk/product...e-oil.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #641778 2nd Sep 2022 1:49pm
DrRob
Page 219 of Owners Handbook
4.4L diesel engine with DPF:
SAE 5W-30 oil meeting specification WSS-M2C934-B
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #641779 2nd Sep 2022 1:52pm
Thanks DrRob… I don’t have all the individual codes to hand… 👍
Post #641786 2nd Sep 2022 2:47pm
garyRR
Also known as STJLR.03.5005. 2015 Range Rover Autobiography 4.4 SDV8
Post #641791 2nd Sep 2022 3:16pm
garyRR
Re: Did Halfords recommend the wrong Oil???
FE 5W-30 OIL
Doesn't look like the correct oil to me. Looks like it's the oil for the 3.6 TDV8 and 4.4 TDV8 *without DPF* (all UK 4.4 TDV8 cars are DPF) that comes up (STJLR.03.5003). You need 5005.
I'm not aware Halfords sell the correct oil. Euro Car Parts will. And if buying online, Advanced Factors and Opie Oils have the correct oils. Smith & Allan are very popular among 4.4 TDV8 users and I personally buy PETRONAS Syntium 5000 FJ 5W-30.
You mentioned you want to do your own service. It is EASY on the 4.4 TDV8 and will take you no longer than an hour. You need a bucket, flat blade screwdriver, M8 spanner, 36mm socket with small torque wrench for the oil filter and a funnel. You also need a strap wrench if changing the fuel filter.
You need:
10L Oil STJLR.03.5005
LR022896 OX153/7D2 Mahle Element Oil Filter
LR011593 (x2) Air filter
LR032199 Pollen filter
LR072610 KC521 Mahle Fuel Filter LR0290
No parts needed but be sure to clean the MAP sensor (1x T20 screw on the "donut")
Lithium grease spray all hinges
Here's a guide I wrote for changing the oil via the drop method: https://www.fullfatrr.com/forum/topic60560.html
Sam has also done a video on servicing the 4.4 TDV8:
Advanced Factors (a site sponsor) can supply you all the parts you need at very competitive prices. 2015 Range Rover Autobiography 4.4 SDV8
Post #641793 2nd Sep 2022 3:20pm
But when ordering from ECP you will need to speak to their operative on the phone, like they are 3yrs old, checking 5 times it’s for the correct grade of oil! And again when it’s delivered!
Hard work ordering from them…
Post #641796 2nd Sep 2022 3:25pm
JayGee
With ECP Online you can specify the ACEC and Ford spec as filter options and it only give you one choice for the TDV8 4.4 which is the Shell Helix ultra at £70. You can get the correct spec oil for 1/2 that at other suppliers. If it says C1 it's the right stuff. 2012 TDV8 Vogue (L322)
Post #641800 2nd Sep 2022 3:46pm
LT
I’m a convert to a Smith & Allan thanks to this and Martins other LR forums:
https://www.smithandallan.com/
Post #641948 4th Sep 2022 1:19pm
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
I’m also a convert to Smith & Allen, very good service and price. They are a Shell agent so it’s possible that their own brand is Shell but don’t know this for sure.
Most online factors quote the incorrect oil for Tdv8 4.4 with DPF, generally quotes the grade for 3.6 without DPF.
Note however, according to vehicle handbook, it is acceptable to top up with no more than one litre with the non C1 5w30.
Best advice from Craig is double check what you have been supplied before filling no matter where it comes from, there is a lot of confusion on oil specs & grades throughout the motor trade - I know I’m in the trade!
Post #641959 4th Sep 2022 5:35pm
Clarky4.4tdv8
FE 5W-30 OIL
You need:
Thanks for this, very helpful indeed
Post #642060 5th Sep 2022 2:45pm
