![]() | Home > Technical (L322) > Is this amount of rust normal? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1405 ![]() ![]() |
Thats normal for a 15 year old car |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 466 ![]() ![]() ![]() |
Cool thanks. So guessing mostly surface rust.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3328 ![]() ![]() ![]() |
The rust in your first picture is on the exhaust, in the 2nd picture it’s on a shock absorber, and in the 3rd it’s on the exhaust again and the rear wishbones.
Thanks.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2622 ![]() ![]() |
Great thanks.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
I would go along with what David said, except your car is much rustier than mine in those three areas so check under the cill covers, mine are quite bad yet the rest of the car looks better than yours.
Ok thanks. Thought it looked like it all needs changing sooner rather than later.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
The bad rust happens behind the plastic sill panel, get a trim tool and pull the trim away where the red line is, you only have to pull it an inch or so, then use a torch and look down behind where the arrow is...
Great advice.
Joek0 Member Since: 29 Jun 2022 Location: Tipperary Posts: 50 ![]() ![]() |
I've been through this recently... as has been said above the only way of knowing is to take off the trim. Mine car looked OK no sign of any rust.. but underneath the trim I was greater with this.
Good to know.
RangeRov Member Since: 24 Jun 2019 Location: Stockholm Posts: 57 ![]() ![]() |
Just went to see a low milage (60K miles) 2009 FFRR in Buckingham Blue in decent condition. It had some brief tailgate rust but also at the rear arches, and only at this spot. The car also had deployable sidesteps.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
Typical for these cars which were never designed to last more than 5 years...... 2012 TDV8 Vogue (L322) |
