Home > Maintenance & Mods (L322) > Screen washer failed
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
So went out on Thursday and wanted to wash screen nothing there just wipers flicking over. Checked fluid level and fine, checked fuse 38 in glovebox it’s fine as well. So ordered a new pump.
Fitted it on Sunday morning but still not working. Checked old pump and it runs.
Double checked fuse today and still ok getting 12v on right hand side of fuse holder, presume fuse is on feed side of switch.
Has anyone had problems with their column switch? Headlamp and rear washers all work fine so wouldn’t expect a broken wire? Next job will be to strip out pump again and check if getting power to it. If pipe to screen is blocked I would still expect to hear pump running for a short while at least. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #642089 5th Sep 2022 7:46pm
Baltic Blue
Does either the rear washer or headlights washer work??
I remember someone discussing swapping things over to help locate problems,
Sorry can’t remember more or find old post.
Post #642105 5th Sep 2022 8:44pm
V8 Bob
Yes back and headlight washers both work however….think I’ve changed wrong pump! I thought middle pump was screen will have to check again! Thanks 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #642115 5th Sep 2022 9:33pm
