![]() | Home > Maintenance & Mods (L405) > Calibrating Rear Parking Brake Actuator? |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
If its anything like my Evoque, BMW 5 and 6 series and my old man’s Scirocco, I generally wind out the parking brake to its full extent, then push back the piston using the actuator side ever so slightly so that its not hitting against its limit, the put the actuator back on.
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
That's pretty much it. I've never known a vehicle with on-caliper EPB to need any calibration. |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 961
I had assumed maintenance mode would wind the parking brake actuator back far enough to accommodate the extra width of the new disc / pads but perhaps mine was out of adjustment in some way - although it all seemed to work ok beforehand despite the cracked actuator casing and water ingress.
Maintenance mode is essentially the opposite of service mode, it drives the piston fully off until the motor stalls, if there is something blocking it, the stall will happen earlier, leaving the piston too far out, which is what it sounds like is what has happened in your case. |
When the motor winds back, it only winds back the inner rod that pushes on the inside back of the caliper piston. This relieves the force on the piston and pads to allow you to take the caliper and pads off the disc.
