Home > Maintenance & Mods (L322) > Steering problem
GustavW
Sweden
Steering problem
Hi!
Another thing.
I recently flushed, and filled the power steering fluid (Land Rover special fluid). because I keep having some sort of judder in low speed high steering input to the left. Not to the right at all...
Wheels are about new, recently also had a 4 wheel alignment done.
It is intermittent, hence really annoying to figure out.
I've checked for clogs in power steering hoses, no leak, no air. A friend helped me check the power steering pump - no noises what so ever. Its all fine until I'm almost full left lock. Steering rack seems fine.
Does anyone have any idea what this could be?
I thought about engine mount or so but went to a LR specialist and he had a spin and thought that was very unlikely. Engine is not vibrating at all basically at idle or so.
Really weird its only on one side near full lock.
Any advice is much appreciated.
Cheers,
Gus Fuji White 2011, 4.4 TDV8 Vogue SE
Post #642173 6th Sep 2022 1:36pm
JayGee
CV joint? 2012 TDV8 Vogue (L322)
Post #642181 6th Sep 2022 2:13pm
GustavW
Sweden
Changed the whole driveshaft a few months ago Fuji White 2011, 4.4 TDV8 Vogue SE
Post #642230 6th Sep 2022 9:34pm
Phoenix
Sounds like a track rod outer ball joint binding to me. - does the steering self-centre OK from left & right hand turns?
Post #642232 6th Sep 2022 9:35pm
GustavW
Sweden
Its funny, I checked the track rod outer ball joint binding, car self centers well etc.
In another thread in the forum Im on about changing gearbox oil and the more I flush the better the steering at full lock left side becomes. Could it be that the gearbox is vibrating because of incorrect oil and that somehow when turning left the vibrations touch the chassis somehow?
Unlikely but not impossible?
Its intermittent to so very strange. Fuji White 2011, 4.4 TDV8 Vogue SE
Post #642409 8th Sep 2022 8:19pm
