![]() | Home > Technical (L322) > 3.6 TDV8 belt and pulleys |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Part numbers in bold below for the highlighted pulley/tensioner.
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 68 ![]() ![]() ![]() |
Excellent! Thank you Gary! Do you know if the idler on the tensioner can be replaced or if I have to replace the complete tensioner assy? |
The tensioner is normally a complete part. 2015 Range Rover Autobiography 4.4 SDV8 |
Thanks again! Now I know what to order |
Does anyone know if the bearings for the idlers and tensioner can be pressed out and replaced individually? I found a used set of all pulleys and tensioner on ebay and wonder if they can be fitted with new bearings. It would be a fraction of the cost of new ones. |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Febest list the pulley as a separate part, a look at their photo clearly shows a bearing that looks easy to swap. I have done this on previous cars so I cant see why it would not be a cheap fix if you are not in the UK like me. Please post the part number of the bearing if you do manage to do it.
Ended up ordering the whole shooting match; belt, tensioner and all idlers. I figured it would be worth it for peace of mind and ease of installation.
