Home > Technical (L322) > Help Please - 2012 Towing Electrics - Sidelights not working
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Grateful for anyone's help as I'm not getting 12 V at my 13-pin socket for either of the tail lights. Indicators, brakes and fog lights all work fine. I have taken the back off the socket and checked the actual wires to ensure it wasn't a loose connection into the rear of the socket and still no 12V so definitely nothing coming down the wire, so to speak. This is with car started and car lights on.
The car is a 2011MY 4.4 TDV8
The tow electrics are a genuine Westfalia plug and play kit. I fitted it myself but I can't see how I got it wrong as you literally just plug the kit into the socket in the spare wheel well and almost impossible to mess up.
I did not need to edit the car's CCF file with my IID Tool but I have checked and the CCF and you can see the settings below
The wiring kit is under warranty so I can send it back to receive another as possibly a fault with it, it just seems so unlikely. Anyway, before I do is there anything else that I should check or anything else that it could be?
I haven't checked fuses but surely there's not a separate fuse specifically for the trailer sidelights in the fusebox, or is there?
Hugely grateful in advance for any advice or knowledge that can be shared. Thumbs Up Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!)
Post #642348 8th Sep 2022 12:43pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Have a read here.
https://www.fullfatrr.com/forum/topic60154.html
Post #642350 8th Sep 2022 1:10pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
If you have a multimeter you could test the car plug that your wire is plugged into to see if there is 12 v on the car side.
The next thing to do would be a continuity check on the new loom from the car end to the 13 pin socket this would identify if there was an internal wiring issue - again you need a multimeter. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #642420 8th Sep 2022 9:12pm
garyRR
Just use a multimeter on the socket, turn on the side lights and check you've got 12V.
Also, just to check you haven't got LED trailer lights? 2015 Range Rover Autobiography 4.4 SDV8
Post #642430 8th Sep 2022 9:44pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Re: Help Please - 2012 Towing Electrics - Sidelights not wor
I'm sure there are separate fuses in the front fusebox near the glovebox. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #642445 9th Sep 2022 6:08am
Ajmngn
So, turns out it was the fuse, great news but frustrating as I’d been trying to trouble shoot it with the multimeter! Haha, just my luck! The passenger compartment fuse box has three fuses relating to the trailer electrics:
- one 30A which is for the trailer circuit (I assume some kind of master fuse)
- one 10A for the trailer reverse lights
- and one 10A for the trailer side lights.
After checking for continuity with my multimeter it was clear the fuse was blown and once changed we’re back to normal again. Phew! I like it when it’s an easy fix!
Lesson learned: always check all available fuses before delving deeper into any electrical problems!
Thanks for the suggestions all as it certainly helped me troubleshoot in a much more focussed way! Andy
Post #642532 9th Sep 2022 6:49pm
