![]() | Home > Technical (L322) > Weird unlocking issue 2011 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I thought that was how it was supposed to work.
Looks like you can change it by pressing lock and unlock buttons together for a few seconds.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
Yes, you can change the settings with the remote or with the IID tool.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
And here was me thinking there was a fault....
The thinking was that you wouldn’t want to unlock all your car if you were alone at night, in case someone got in another door…… or maybe that’s me just spreading nightmares 😱
...depends where you are and what activity you're up to... 2015 Range Rover Autobiography 4.4 SDV8 |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 46 ![]() ![]() ![]() |
Has anyone had a change in mirror light behavior regarding one press lock vs two press lock? On my MY07 mirror lights worked just fine when it had two press lock but now that I changed the setting with IID-tool to one press lock, mirror lights practically just blink and off they go. The cherry on the cake is that now, even if I change back to two press lock, mirror lights just blink and I can´t get them back to normal operation |
Anyone? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
Try putting them how you want, then do a battery reset, if you play with the CCF you sometimes have to do a reset.. |
Battery has been disconnected once after the change in configuration, will try again. |
Changed the FBH few days ago and had the battery disconnected for over an hour, still no change in mirror light behaviour, just a blink when opening the door locks. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Easy Unlock is on the instrument panel menu iirc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
