Home > In Car Electronics (L322) > 2008 GPS
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
2008 GPS
Where do I find the GPS receiver in a 2008 Vogue please? The sat nav (that I’m not using but I want it right!) shows no GPS and there’s a GPS fault showing in IID.
 Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #642597 10th Sep 2022 2:39pm
Weegie
The receiver is integrated in the nav unit in the left rear cubby hole. A possibility is that your gps aerial on the roof may need replacing.
Not an uncommon fault at that age. Do a forum search for gps aerial .
Just had a thought. When you installed the Navtool you may have disturbed the aerial connection at the back of the nav unit - the blue plug - as I assume you had to remove the unit to make the connections at the rear. John
GAP iiD BT
Post #642598 10th Sep 2022 2:50pm
tymh
Thanks Weegie. If it’s a big job then I’m not bothered as I use CarPlay now anyway. I’ll have a search…
Would just be nice to have it as it should be. Tym
Post #642601 10th Sep 2022 3:11pm
Phoenix
Any GPS receiver that works on 5V will do, I used an old Garmin external receiver to resurrect mine, took the roof pod off, gutted the failed receiver out of it, Araldited the replacement in, refitted and ran the cable down the 'D' pillar to the navigation unit, drove round for 20 mins. so it could 'learn' the visible satellites and it's been fine ever since. Cost £0, time taken, 1.2 hours.
You may need an adapter cable depending on which GPS receiver you use.
Post #642613 10th Sep 2022 6:09pm
tymh
Thanks phoenix
I’ve got a spare usb one somewhere if I can be bothered taking the roof block off. Tym
Post #642616 10th Sep 2022 6:38pm
Phoenix
USB one won't work... it needs data over power (co-axial connector) if you CBA to take the roof pod off, you could always blu-tack it to the trim in the boot next to a side window until you can 'BA'.
ETA https://smile.amazon.co.uk/Eightwood-Anten...07314BQRB/
I honestly can't remember if the Nav. unit has a male or female Fakra connector so you'd need to check.
Post #642618 10th Sep 2022 6:48pm
tymh
Thanks for the link Phoenix.
It’s one of jobs on my do-it-when-everything-else-is-done list.
I can set the position in the sat nav so it ‘knows’ where I am, but as I use CarPlay all the time having the factory sat nav working with the GPS isn’t a huge priority.
I’ll bookmark this so I can come back to the link you posted. Really appreciate that thank you. Tym
Post #642619 10th Sep 2022 6:58pm
Phoenix
No worries - I tended to do some of the less-important jobs in lunch breaks at work so actually ended up doing them before the other jobs that needed more time / money investing in them!
Post #642620 10th Sep 2022 7:07pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Tymh i have a gps receiver i bought to plug into mine that you can put in the window. It's now surplus as I've just had a genuine roof antenna fitted to mine. It has the fakro plug so will plug directly into your satnav unit in the boot. £5 posted and it's yours.
Post #642784 12th Sep 2022 6:26pm
tymh
Thanks but for now I’ll pass. It’s not something hugely important and I’ve got other issues (not car related) that need my attention at the moment.
As I use CarPlay anyway this was just a case of wanting it back (eventually) as it should be there.
Really appreciate the offer though. Tym
Post #642790 12th Sep 2022 7:08pm
Phoenix
If the offer is open to anyone, I'll take it - No.2 Son has a Disco3 with non-functional GPS and it's the same Nav. unit.
Post #642806 12th Sep 2022 8:54pm
