![]() | Home > Maintenance & Mods (L322) > Is jacking on the tow bar safe? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
I've jacked up the complete rear of mine using the towbar with no issues.... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8781 ![]() ![]() ![]() |
I'm with dingg1, used it several times to jack the back up and it doesn't deflect 1mm.... |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
Recommended nose weight has little to do with the inherent strength of the tow bar itself.
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
Many thanks for the replies, worth checking before I made a big mistake! |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Pretty sure the workshop manual says the crossbar of the tow bar or the chassis rail between the exhausts can be used. 2015 Range Rover Autobiography 4.4 SDV8 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
If you do use a trolley jack on that point be careful of the jacks arm swing, as it comes up the jacking pad moves backwards and the jack may fall off before the wheels are off the ground....
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3324 ![]() ![]() ![]() |
I'd only jack on a single point with a very large 'garage' jack - the ones you have to drag and are too heavy to lift and have a wide set of feet to cope with any lateral movement. As said 2 jacks either side is far safer. 2012 TDV8 Vogue (L322) |
