Home > Technical (L322) > Fan starts running when opening door (FBH) |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Well, the door status is broadcast on the K-Bus, which is the one the FBH is connected to, it sounds like the controller is taking the door status (and likely other messages as well) as the 'startup' message. The fan runs initially before any combustion is initiated as a self test (which it is failing) so there won't be any other DTC's.
15th Sep 2022 2:51pm |
revier Member Since: 12 Aug 2022 Location: Finland Posts: 4 |
Thank you for your reply. Is the control board under the battery tray, same place as the FBH? Might aswell take a peek. |
15th Sep 2022 3:13pm |
The control board is part of the FBH - it's behind the plastic moulding with the electrical connectors on it - which itself has a plastic cover over it.
15th Sep 2022 7:07pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 762 |
I occasionally have the same problem
15th Sep 2022 8:46pm |
I appreciate your answers |
15th Sep 2022 9:20pm |
Ei hätää!
15th Sep 2022 9:33pm |
I have dual batteries and they are fairly new. Wouldn't hurt to hook up a smart charger though. |
15th Sep 2022 10:17pm |
