![]() | Home > In Car Electronics (L322) > Amzon Echo Auto |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
Take a look at the Bovee Bluetooth adapter? It just plugs into ipod dock inside the arm rest and allows you to use Bluetooth streaming / audio from your phone.
Garymahoo Member Since: 15 Jul 2022 Location: Aberdeenshire Posts: 49 ![]() ![]() |
Thanks Gary.
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
I have both the Bovee and the Amazon Echo Auto. I have the Echo linked to an Alexa Routine to Open my Gate via Voice when I am approaching my home, so that the gate is fully open by the time I reach the driveway.
You can set both Google or Alexa on your phone up to respond to a voice command. It will use the microphone on your phone (which are sensitive enough these days then play back the audio through the bluetooth to the car anyway). The Bovee adaptor allows you to use the next and back controls on the steering wheel, assuming you use Spotify/Apple Music/have music stored on your phone. So, I'm not really sure what other value the Echo Auto would add vs what your phone can already do. There is one other option - there's a thread on here. There's a cheap CarPlay screen (about £125 iirc) which only needs a power source - it mounts above the existing screen (for me I'm not overly keen on that) and all you need to do is run the power cable down to the fuse box. It has Bluetooth so, again, all audio will come through your car stereo. 2015 Range Rover Autobiography 4.4 SDV8 |
