![]() | Home > Maintenance & Mods (L322) > Propshaft Centre Bearing Failed |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Those that have been following my project pages will know that I have already changed the propshaft centre bearing once. Its only covered about 2000 miles since being changed but it's self destructed already.
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 149 ![]() ![]() ![]() |
If you paid by credit card might you be able to make a claim against then under (from memory) section 75 |
It has got to be over £100 for the section 75 apparently. Christian.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 991 ![]() ![]() ![]() |
which company did you use in the end for the centre bearing ?? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8792 ![]() ![]() ![]() |
It's been said on here a few times that just replacing the bearing can be false economy, I dare say some have lasted a reasonable time but a lot have had premature failures, a genuine new complete propshaft is the only way to ensure longevity.. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Jayk69 what's a new prop shaft cost pls for the part?
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
A new propshaft from LR is in the region of 800 quid.
I marked mine but there is no need as the centre joint only goes together one way. There is a double width spline. Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Christian, i was not suggesting you had not done the job proper i have seen your videos so know how studious you are. i have to say i did not clock the double spline on mine!! everyday is a learning day. |
