![]() | Home > General > Big thanks to DCC 4x4 in London |
Do your Bi-Xenons work as they should? ie the shutter move? They don't tend to wire these up.
BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247 ![]() ![]() ![]() |
Did you take your car to DCC? My xenon lights work perfectly as they should yes. No electrical tape. Headlight washers do not, but that's because mine is 02-05. To get this working requires additional parts of which they offered me and I choose not too. Used to have: 2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped Now have: 2008 SSRR 3.6 TDV8 - HSE and plenty of toys |
Pictures me thinks BigJ..... |
Your Xenons might - but do your Bi-Xenons?
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Sorry to rain on your parade BigJ, but it's highly illegal to not have a working headlamp washer with Xenon headlamps. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
Apart from the odd dodgy looking chrome accessory which they even owned up to being a bit OTT, we hear nothing but praise about these guys, how refreshing.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Dan, as the risk of opening up a hornet's nest here, do you know that DCC definitely did the work on your RR?
Yes. Also the others. I believe Daveo had his done there and his headlights/washers were also missed. I think unfortunately people don't necessarily know what they have missed off. You wouldn't know your Bi-Xenons weren't working unless you knew how they operated in the first place. You might not realise your headlight washers aren't working. Although with Xenons making their way into MOT's very soon this will become more of an issue for some... BigJ - what happened to your SIA pump? You should have the large cone air filter, and then a smaller cone filter about 6 inches lower down. Missing this and you're using unfiltered air. ![]() Last edited by dan_uk_1984 on 17th May 2011 7:25pm. Edited 1 time in total |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
While I don't want to comment on the supplier in question, as I've never used them, you don't have a choice about headlight washers.
Don't I feel the arse now! I thought it was all good feedback? Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top 1998 90 TUL FFR Hard Top XD Wolf 1993 90 Tdi *Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
To be fair nobody has actually inspected the work on BigJ's car it may well be excellent and as would be expected from a FFRR Site Sponsor.
Are you talking about Powerful_UK or DCC Conversions? I'm talking about the latter... ![]() |
2 or 3 years ago, I'll dig the paperwork out. Not sure when Dave had his done? I don't really have to give them the "benefit of the doubt" as I have a car they've converted, and it's shocking! Honestly, it's terrible. I've sealed most of the connections now so they are good for a while, but will never be great. Instead of changing the headlight plugs they just cut the wires and inserted the pins into the new sockets, but didn't use the rubber sealers in each pin hole. As I said, the Secondary Air Injection pump had been overlooked on mine, and all others I've seen. This basically means that the intake system has a gaping hole in it 2 inches wide at bumper level. Imagine wading in anything over a foot deep! I wouldn't sling mud if there was no mud to sling. ![]() |
i had my conversion done in october 2009 and found the job as a whole very good and was happy but on learning more about my car i did find out a few things, my bi-xenons were not wired up, there was no filter on the secondary air pump,my washers are not plumb in and i seem to have a gap between the head lamp and wing that had a bit of rubber pushed in the gap. looking on other RR the head light fits tight against the wing. my S/C tails lights started condensating up after about 6 months. my be these were issue they had at the time and now have over come them, i would welcome the offer of any fixes from them, the head light washers can be plumbed in using the the pump that would of been used with the original headlamp washers just remember to keep the hose the same length for both sides. V8 facelift Range Rover Autobiography 22" wheels.
