Home > Wheels & Tyres > 275/55/R20’s to 275/60/R20’s
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
Ok, stay with me here.
I currently have 275/55/20’s on the L322. Coopers, AT3’s they will need repacing before next spring, they have taken a beating this year off road in Spain and Portugal, 10K miles and they are showing wear.
Need more sidewall, more protection to rim damage, so thinking of going up to 275/60/r20’s
I can lift the L322 to +55mm, I can go higher too with the easy lift, have been driving around in Spain, on and offroad +55MM Ok. Fitting them should work without any rubbing, or trimming. Access mode might be tight, but I can play with the settings to avoid the bump stop arch rub.
I can’t go to 18”’s before anyone starts, I have front 6 pot brembos, currently, no wheel fits, compomotive might have an option soon, but doubt it will be here within 12 months.
BFG’s KO2’s are available in that size
Thoughts? Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #643712 23rd Sep 2022 3:41pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i bought some for mine 275/60/r20’but i havent fitted then, sure they wont fit RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #643985 26th Sep 2022 9:08am
knares
can you get the 55s in the spare wheel compartment RR 2005 4.4 petrol
Post #643988 26th Sep 2022 9:51am
GraemeS
Australia
I did but had raised the floor on sponge blocks and had pads under the tyre to stop it becoming wedged in.
Post #643990 26th Sep 2022 10:00am
2010BlackL322
Not without taking some of the air out or removing all the padding. Mine won’t fit. Check out my YouTube channel
Post #643992 26th Sep 2022 11:45am
