Home > Technical (L322) > Invisible oil leaks... 4.4 TDV8
fmgl322
Germany
Morning chaps,
On Tuesday I finally did the oil-cooler feed pipe O-rings with Viton 611s and, apart from dropping the bolt down the back of the engine, thought all was well. After a good scrub of the oily bits, an undercarriage wash and blast I watched a couple of drips of old oil (I thought) make their way down to the frame and on to my driveway. No big deal.
Last night however I noticed a fair bit more oil on the ground and took everything apart again to look more closely. Everything around the cooler *appears* clean and dry. The pipe is clean and I can't see any obvious signs of oil escaping anywhere.
To add to the horror - I saw 1 single drop of oil floating about in the coolant reservoir. Is it possible that doing the O-rings has somehow increased pressure on the cooler gasket and it's now ready to be done?
I already bought the gasket(s) for the oil cooler, so I suppose that's next on the list. Be honest - how much of a pig of a job is it to do? What would you add to the "while you're in there" list of things to do? I'll replace the still original donut hoses and clean that area out - it would make sense as it's all got to come out anyway. Anything else worth doing?
Thank you all for your posts and help on this amazing forum. It actually makes me look forward to things going wrong! Rolling Eyes
Post #643787 24th Sep 2022 11:38am
JayGee
Sounds like either the gasket or the cooler have a leak if there is oil in the coolant - almost inevitable on these engines. 2012 TDV8 Vogue (L322)
Post #643792 24th Sep 2022 12:01pm
GraemeS
Australia
There are 2 coolant fittings where people have found the o-rings perished. 18mmx2.5mm Viton o-ring has been used on the one at the oil cooler and the other appears to have 18 x 3.0 marked on the housing which could be the o-ring size. I've sourced both sizes with the idea to replace both when I investigate the cause of a slow coolant loss. I've already replaced the cooler gaskets.
Post #643795 24th Sep 2022 12:25pm
fmgl322
Germany
Thanks - how likely is it for the cooler itself to fail? Can it be tested or inspected in any way without tearing everything apart?
OR - should I just bite the bullet and replace the whole thing to be 100% safe for the future - I want to keep this car long-term and want to get everything sorted properly...
Any offers out there on coolers at present? Very Happy Part No?
Post #643796 24th Sep 2022 12:36pm
DrRob
Replace the whole thing. Been known to warp.
Use Advanced Factors. Forum discount code AF4LRP Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #643800 24th Sep 2022 1:18pm
garyRR
As Dr Rob says, the oil cooler is pretty well known to warp in a good proportion of cases. Even a good gasket can't solve that. 2015 Range Rover Autobiography 4.4 SDV8
Post #643802 24th Sep 2022 2:16pm
fmgl322
Germany
Evening all,
I've decided I'm going to replace the oil cooler as a unit and hopefully cure the problem once and for all. Thanks to the magnificent instructions here in the forum, I'm confident that that should fix the drips. As the donut will be off during the swap, I'm going to replace the hoses and clean everything out along the way. Does anyone have a part number for me for the (new design) original LR hoses? Is there anything else you'd suggest doing while I'm in there?
I was digging around under the car the other day and noticed more oil dripping from further back, closer to the gearbox. As the car is parked on a sloping driveway I just assumed that was gravity doing its thing, but when I looked again today I saw there had been quite a bit more dripping down. The car has not been out in the last 48 hours. Is there something further back that could be causing a leak like that, or could it just be accumulated oil spread back there during trips? As far as I can tell, it's engine oil. I hope it's gearbox oil leaking out - I have NO idea when or if the gearbox has ever been serviced (it's on the list of things to get done externally), but it's doing its job perfectly, so I don't suspect there's anything wrong there.
What do you think? Am I now being paranoid about oil leaks (yep, they're even appearing in my dreams!), or is this all just part and parcel of 10-year-old RR motoring? Laughing
Thanks and more anon... -------------------------
2012 4.4 TDV8 Vogue
2001 Audi A2 1.4 16V
2019 Skoda Kodiaq (don't ask...)
Post #644234 28th Sep 2022 8:41pm
garyRR
Save yourself some money and just get some 70mm hose.
Otherwise 4 small hoses will cost you £170. 2015 Range Rover Autobiography 4.4 SDV8
Post #644236 28th Sep 2022 8:44pm
fmgl322
Germany
Where is the other coolant fitting? Pardon my ignorance - the one on the cooler housing is obvious enough, but where's the second one you mention? -------------------------
2012 4.4 TDV8 Vogue
Post #644237 28th Sep 2022 8:44pm
GraemeS
Australia
It's closer towards the front of the engine.
Post #644244 28th Sep 2022 9:43pm
