![]() | Home > Technical (L322) > SRS Module/ RCM Module |
Jamesh7216 Member Since: 30 Dec 2021 Location: Baschurch Shropshire Posts: 46 ![]() ![]() ![]() |
I have a 2006 TD6, Icarsoft CR Pro shows up a Link Error when trying to connect to SRS and and Land Rover SDD does not recognise the Restraints Control Module. Any advice on where to start looking would be appreciated |
Thanks for your prompt reply Phoenix, can you be more specific please, which +ve and-ve connections do I check and how do I check data lines (CAN-H) |
Here's the wiring diagram, there is no CAN-H, that's later vehicles, it's K-BUS which is single wire (pin 9), expect to see 7-12V on that, the +ve is on pin 5, the module appears to be grounded through it's mounting so unless it's corroded around it's fixings, that should be OK.
Thanks for the prompt reply and information, I'll try that |
apsona Member Since: 17 Mar 2022 Location: Nice Posts: 5 ![]() ![]() |
Hi there,
Thanks for the reply, that is interesting I will try that before removing the centre console to test the module |
If you've also tried SDD, then it's unlikely to be a protocol error. |
Thanks for the reply |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1010 ![]() ![]() ![]() |
Phoenix, that really helped me a lot, thank you - my SRS ECU is knackered I am pretty sure
SRS modules are VIN-tied when coded during fitting, the coding (i.e. what is fitted to the vehicle) should be the same if it's from an equivalent model year.
Phoenix - thanks for the heads up, we carefully swapped out the SRS ECU and took note of your advice, and it seems to have worked for now, fingers crossed |
Good result! - the other thing is I suppose you never know if the replacement module is any better until you power it up. Are there any DTC's due to the VIN change?
no faults on Snap-On scanner, and no fault codes on my IID scanner
Sorry, I meant what was the reason for changing it? |
