Home > Maintenance & Mods (L322) > Wiper blades.
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Wiper blades.
My wiper blades are quite noisy so will try to clean them up but if that doesn’t work what are your recommends? Stick with the oem ones (part numbers dkc000040 / LR155029 are what I have found) or buy some Bosch ones for example?
Also the drivers wiper arm seems to have lost some of its black coating oddly so will try to respray or buy another, guess it’s just a bolt on-off item.
Post #643862 25th Sep 2022 9:27am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Go for Bosch. Wiper arms are a bit of a fiddle due to poor spanner access, but doable. I changed the arms for new after nine years - what a difference. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #643863 25th Sep 2022 9:45am
JayGee
Thumbs Up for Bosch. Also check the joint on the OS wiper linkage as these can split and detach leading to the arms colliding with each other and causing further damage. 2012 TDV8 Vogue (L322)
Post #643864 25th Sep 2022 9:49am
KitTheRam
Thanks, can you recommend a particular Bosch wiper (model number / name).
As far as wiping the blades seem to keep an even distance away from each other at all times - just bloody loud!
Post #643865 25th Sep 2022 9:55am
JayGee
https://www.boschwiperblades.com/home 2012 TDV8 Vogue (L322)
Post #643866 25th Sep 2022 10:03am
KitTheRam
Thanks. These it is then.
Post #643867 25th Sep 2022 10:10am
KitTheRam
For anyone else in the market for these I just got them (x2 blades) for £17 delivered on eBay using the voucher code ‘Deal20’ which took 20% off.
https://www.ebay.co.uk/itm/352166182854?mk...media=COPY
Post #643869 25th Sep 2022 10:19am
Dolphinboy
Nice one. Just ordered a pair for winter! Thumbs Up
Post #643975 26th Sep 2022 12:00am
