Home > Technical (L322) > Diesel Additives. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2706 |
Tried a few on various cars inc (BG44 and 2 stroke) - never did anything apart from lighten my wallet . If I had a 3.6 the first thing I'd be doing is to blank and software delete the EGR valves before they go wrong. Plenty of reports of these engines running better after this and turbo's being spared death by egr parts ingestion. 2012 TDV8 Vogue (L322) |
26th Sep 2022 3:58pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 308 |
Interesting. Are there any know problems from deleting the EGR’s (guessing not by your note).
26th Sep 2022 4:03pm |
When I was looking to buy an L322 a 3.6 was an option so I did some research on it ( Blanking plates from Ebay and software delete via the GAP IID tool) but best get advice from others who have actually done it as to what improvement it made and what the downsides are. 2012 TDV8 Vogue (L322) |
26th Sep 2022 4:10pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1122 |
I had a very noisy injection pump and put some Millers ecomax in the tank and the noise went away. Coincidence? |
26th Sep 2022 4:45pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
I regularly used BG44 in my 3.6, it did no harm but then again did it do any good? Geoff |
26th Sep 2022 4:46pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 649 |
speak to Empire in Colchester - one of the very best remap shops around for Range Rover ( and not far from you)
26th Sep 2022 5:04pm |
What little I have read on EGR deletes included mentions of it being an mot failure if spotted. Not sure how true that is but read it a few times now. Also issues with the engine management light seem common. But I guess if done by a specialist garage these issues would have solutions, you would hope. |
26th Sep 2022 5:07pm |
Thanks for the tip @pcourtney. |
26th Sep 2022 5:09pm |
speak to Empire first, they are able to do all this in softeware without falling foul of the MOT regime etc |
26th Sep 2022 6:46pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Blanked / missing EGR's are a MoT fail.
26th Sep 2022 6:50pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 201 |
Yeah- it is a MOT fail, but a tester would never see it as it’s a) under the bonnet and b) under the engine cover and they cannot and have no reason to lift it, so it would never get spotted 2007 TDV8 Vogue SE
26th Sep 2022 7:04pm |
Yep, forgot to add the 'if modifications are visible' bit!
26th Sep 2022 7:15pm |
Thanks for the all advice so far.
26th Sep 2022 7:28pm |
The egrs will only ever be touched when they go bang 2007 TDV8 Vogue SE
26th Sep 2022 7:34pm |
