![]() | Home > Maintenance & Mods (L405) > Ceramic coating |
| Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223
Yes, the ceramic coat was on top of Auto-Glym super resin polish. This was applied following removal of contaminants using a clay mitt and detailing spray SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1024
just looked at my Sumatra Black in the sunshine today ( its really very very dark pearl blue, purple) , and so pleased I did the ceramic coating, all I do once every two weeks is "Snow Foam" some Bilt Hamber Auto-Foam, let it dwell for 4 mins, and pressure washer it off, then run the micro fibre mits over it till I'm happy - job done |
| oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397
when you have done washing and moping dry go over with a detailing spray i use g3 pro 7193 detailer. i also use pure water on the final rinse through the power washer . then you do not need to mop dry and less scratching
nice SC - nice colour |
hi you are supposed to use it after every wash and yes it is easy to apply just spray on a panel wipe over leave move to the next panel then go back and wipe off you will be happy with the outcome. okay, ref the filter it will work but not for long you do not have to buy loads of pure water you need to buy a canister that will filter the water as it goes through your power washer. or put it in line with a garden hose this is where i buy my filters from daqua from Scotland di resin water filters bigger the better bottle when spent out just replace the resin. the glass comes up like new and no staining much the same system as the window cleaners use final rinse and leave it dry then on with the g3 after fully dry job done and yes do the roof as well pain i no just get a good hop up .
the filter I found in my garage - is INLINE with hozelock fittings - just like the one you have ( albeit yours is a bigger cannister by the looks of it ) |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346
Except Oggy's canister is filled with a DI Resin, not a filter.
got it, the old filter is no good anyway, so I will buy a new 10" DI Resin Holder Cartridge filled with resin |
hi your filter will work but not for long maybe a couple of washes ? my di vessel is the 23.6 ltr 8x 35 with the mb115 resin in it and you have to buy a water tester, not much money that will let you know when the mb115 resin needs replacing if you use ref garden hose you get about 80/100 washers put it in line with power washer you are like to get 50 washes . but none at the moment as we are still on hose pipe ban . so it is hand ball job at the moment .
thank you
hi pcourtney very good link lot cheaper than my supplier this is what you need use this with your snow foam as well pure water all of the way you will have to put a pair of shades on after washing it you will have a nice set up . oggy new vehicle purchase
