![]() | Home > Technical (L405) > Bobbly braking |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
It could potentially feel like that if they introduced a bit of air into the system when they did the fluid change.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
Sometimes when the brake caliper pistons are corroded and are pushed back (without being cleaned off) when new pads are inserted they can become sticky, and the sticking will produce a juddering. That happened when I had new pads on my first 322, though there there was also some tearing of the rubber gaiter which might have fouled the piston. If the car can safely be stopped after the juddering is felt you could see if the wheel is hot which would be indicative of a sticking piston (with care to avoid getting burned). Only Range Rovers since 1988 |
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 242 ![]() ![]() ![]() |
I had a similar thing after service, took it back. They said that there were marks on the discs, possibly from standing too long after wet driving. They removed, and cleaned all the discs (expensive) it was ok after that. 2013 SDV8 4.4 SE Luxor.
