Home > Technical (L322) > Shift Solenoid 2/Trans Fail Safe on ZF5HP24 gearbox
SLB23
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi Everyone,
About 6 months ago i bought an 03 L322 4.4 LPG. Absolutely love the thing but recently it keeps going into trans fail safe after about 15 minutes of driving. I changed all the oil with genuine filters & oil but it didn't fix the problem. I bought an IID tool which has already paid for itself on other things. It keeps popping with "Shift Solenoid Fault 2" i've tried looking on the internet to find one but i cannot see anything & LR want £550 for a new harness. There's no judders or clunks when it changes gear when it's not in fail safe. I was wondering if anyone knows where i can buy one so i can replace it? Or if anyone knows any alternative solutions?
Thanks
Post #644602 2nd Oct 2022 9:47pm
RRPhil
I could test your solenoid for you, although it’s probably easier just to send you one to swap out and see if the problem disappears (MV2 in the photo). It’s just as likely to be the wiring harness at fault, but substituting the solenoid is a good first step.
Phil
Post #644611 3rd Oct 2022 12:56am
SLB23
Brilliant! How do i go about buying one from yourself? If it was the harness are you able to just swap them out?
Many thanks for your help!
Post #644685 3rd Oct 2022 9:00pm
RRPhil
Yes, the internal wiring harness can be swapped out as well with the transmission in situ. Replacement of the solenoid and the wiring harness are both covered in RAVE so it’s a job that Land Rover even allowed their technicians to do.
I can send you a used (but tested) solenoid for £25 + postage and, if it doesn’t fix the problem, you can send it me back and I’ll send you out a used (but tested) wiring harness (£100 + postage less £25 refund on the solenoid = £75 + postage). You can also return the wiring harness for a refund in the unlikely event of it not fixing the issue.
Send me a PM if you’re interested.
If you’d rather fit brand-new parts, I can point you in the right direction for sourcing them.
Phil
Post #644702 4th Oct 2022 12:27am
SLB23
Fantastic i'll drop a dm now
Post #644798 4th Oct 2022 10:33pm
SLB23
Finally got round to putting the harness & solenoid in the transmission & now it's all fully working as normal. Can finally drive longer than 10 minutes with no warning sounds! Big thanks to Phil for helping & selling me the parts. Onto the rest of the list now!
Post #645799 16th Oct 2022 10:40pm
RRPhil
Post #645805 17th Oct 2022 12:24pm
richyx
sorry for dragging up an old post but ive just come across this and registered to get some info but seems i cant pm you
i have a similar issue with this, when you say wiring fault is that that a break in the wire or just dirty terminals? im going to be giving my box a flush with new filter but after reading this im not reconsidering it
its the zf5hp24 box are the wiring looms the same throughout the zf5hp24 boxes? and solenoids lie from bmws as well?
Post #680189 13th Dec 2023 10:04am
richyx
or if anyone knows where i can get spares for the gearboxes
Post #680247 13th Dec 2023 9:03pm
richyx
error code im getting is 4 pressure regulator solenoid 4
Post #680248 13th Dec 2023 9:04pm
RRPhil
So, the shift solenoids are the three ‘brown body’ solenoids (MV1, MV2 & MV3) and the pressure regulator solenoids have the black caps (EDS2, EDS3, EDS4 & EDS5).
EDS1 is a pressure regulator with a green cap and this works the opposite way round to the black cap solenoids i.e. increasing current reduces pressure, rather than increasing it. This is used for controlling main system pressure and is designed to failsafe to maximum pressure in the event of the electrics being lost.
Your error code appears to indicate a fault with EDS4.
You can check if the solenoid windings and the wiring loom are intact by measuring the resistance between pins 11 & 16 at the 16-pin connector at the rear of the transmission. The reading should be around 5.8 to 6.0Ω
If the resistance reading is incorrect, you will have to detach the loom from the solenoid and then re-measure, to determine whether it’s the solenoid at fault or an issue with the wiring.
If it’s easier, you could also measure the resistance at the transmission ECU under the bonnet (between pins 7 & 21). This has the added advantage of checking the rest of the transmission wiring loom, too.
Identical solenoids and wiring loom were used in later BMW and Jaguar models fitted with the 5HP24, but you need to avoid very early models.
Phil
Post #680252 13th Dec 2023 9:56pm
richyx
ive sent you a pm as well
so if i can measure the resistance at the ecu would this show me a wiring fault or solenoid fault if the resistance is wrong?
can you supply solenoid and loom? i did have a box change when i bought the car 6 years ago but i only know they fitted a same moel i couldnt tell what year it came from though
Post #680263 14th Dec 2023 12:49am
Gsxr1250dave
Calling Phil calling phil
Hi Phil
Fun and games with my 4.4 m62 now. Failsafe after 10/ 25 mins driving shift solenoid 2 is my code ivhad the solenoids out they all test OK so looks like iv a faulty harness. Would you have one I can buy ? By chance
Thanks
Dave
Post #716719 24th Apr 2025 1:43pm
RRPhil
Hi Dave,
Sorry to hear about your issues. I still have a few used internal wiring looms knocking about but they’ve been in my garage for years and I can’t remember their history. I wouldn’t feel comfortable supplying these to anyone as ‘working’ looms in case they were faulty.
You can still get new looms, and they seem to vary in price from around £160 up to £225. Identical components were used by BMW, Jaguar and Land Rover so it’s worth searching against their own part numbers, as well as the ZF part number.
Land Rover - YMD001500
Jaguar - LNC3380AA (which superseded JLM20218 )
BMW - 24341423719
ZF - 1058 227 019
I used to buy mine from either JPAT or Sussex Autos under the ZF part number, as this was the cheapest source back then.
Phil
Post #716762 25th Apr 2025 10:35am
Gsxr1250dave
Thanks Phil have orderd new as you suggested
Thanks
Dave
Post #716775 25th Apr 2025 1:54pm
