Home > Technical (L405) > Raising the suspension form the key
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys I have seen a few topics online relating to being able to raise and lower the cars suspension form outside vehicle using the key is this correct as I have tried but nothing is happening!
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #644620 3rd Oct 2022 9:43am
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
This?
To change the suspension height using the Smart Key, the vehicle must be stationary, all the doors closed and the hazard warning lamps switched on.
To raise the vehicle, press and hold the Approach lamps button (1) and the unlock button (2) together.
To lower the vehicle, press and hold the Approach lamps button (1) and tailgate unlock button (3) together.
Note: If there is no height movement after pressing the buttons for 10 seconds or more, or if unexpected behaviour occurs, press the Approach lamps button (1) twice and restart the procedure.
Note: If the starting height is above or below normal height, movement will stop when normal height is reached. Release the Smart Key buttons and press again to continue.
Never tried it myself Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #644629 3rd Oct 2022 11:05am
jaysta10k
Cheers for this bit strange hazards have to be on first would be a much better function if this wasn't the case being able to lower the car for better access without having to put hazards makes no sense as you have to open the car first put hazards on then lower from the key
Cheers
Previous Cars
BMW M3 Carbon Black
Post #644635 3rd Oct 2022 11:35am
It's purely designed for attaching and removing trailers, they have made it so it's not easy to accidentally lower it onto someone/thing...
For others info the later 322's do it also.... Thumbs Up Pete
Post #644637 3rd Oct 2022 11:54am
jaysta10k
ok makes since I suppose
cheers
Previous Cars
BMW M3 Carbon Black
Post #644638 3rd Oct 2022 12:00pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
has anyone confirmed this works on all l405s? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #645379 11th Oct 2022 4:07pm
Who could confirm that...!!
It's in the handbook over here but then all options are....
I guess you will have to try and see.... Thumbs Up Pete
Post #645393 11th Oct 2022 6:17pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
I have used it a few times for the tin tent - it's pretty cool but I agree having to put the hazards on is a daft pain in the rear FFRR SDV8 Autobiography
Post #645429 12th Oct 2022 11:27am
TJH1985
I use it for unhitching, enables you to leave the front of the trailer nice and high i.e raise suspension then unhitch by lowering the car while holding up the hitch handle Thumbs Up
Great feature IMO and usually in my scenario you have just driven somewhere, so it's not hardship to pop the hazards on before you get out? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #645430 12th Oct 2022 11:42am
