![]() | Home > Technical (L322) > Low battery warning question |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
I turned my interior courtesy lights off when the doors were going to be open for a while. I've just replaced all the interior lights with LED's so I can just leave them on now |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
It was a deliberate design feature that the AGM battery never gets fully charged and the nearer 80% charge is reached, the car automatically reduces the charging current.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
As above…. If you keep the interior light switch pressed in for a few seconds, it will flash and be disabled till you turn them back on again, using the same process. Might help a bit if you are in and out the car a lot.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 991 ![]() ![]() ![]() |
Hi Ben
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
@Ben,
BenRK Member Since: 19 May 2020 Location: County Durham Posts: 164 ![]() ![]() |
Thanks for all your replies
I've got the same charger mate, had it for 4 years with no problems.
Did it fix your battery or do you use it frequently mate? |
I had my battery changed because it kept saying low.
How does that connect in to the charger mate as mine just came with two large crocodile clips on the end. I've seen some where they come with rings you can connect direct to the battery. Cheers |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
I have had this issue in the past, 2 solutions that I use
It never ever fails to start I just hate the low battery message |
I have the same two piece connector on the charger end that you can see under the bonnet. I connected the wire with a bolt through the crocodile clips. Get the three pin connector plug because it will only connect one way so you know the polarity will always be correct. |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2622 ![]() ![]() |
One of the biggest irritations on my 2011 L322, actually got the dealer to look at it out of warranty via customer services. Never stopped doing it (and the L405 does it too, albeit less often). |
