Home > Technical (L322) > 2011 4.4 TDv8 Judder
Jamesonfox
The exhaust.
Post #645075 8th Oct 2022 1:13pm
JayGee
Logic would suggest the injector is firing and filling the cylinder but there is not enough compression to ignite it. 2012 TDV8 Vogue (L322)
Post #645087 8th Oct 2022 2:33pm
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
Can you guys, who have done the PCM update by LTB00454v2, share your PCM (or ECM) data? I want to know if mine has been done, so need comparsion data. I've also felt a juddering few times, while cruising at highway speeds over 110 km/h. Really worrysome feeling.
My PCM data is here:
PCM-Engine TDV8 4.4L (No update found)
Assembly (F113)
BH42-12A650-NAD
Calibration (F124)
BH42-12K532-NTL
Hardware (F111)
BH42-12B684-NA
Serial
1373020506111015
Strategy (F188)
BH42-14C204-NTD
Hope someone would find a minute to pull and share data. Smile
Cheers
Keijo
Post #647805 10th Nov 2022 10:06am
pvb1@sky.com
United Kingdom 2011 Range Rover SE TDV8 Santorini Black
I’ve had the same issue. Juddering at 20mph when you lightly touch the throttle then disappearing if you floor it. The problem was cylinder 6. Burnt inlet valves, no compression. Took months to find issue as these engines are by reputation bullet proof.
This was on a 2011 L322 4.4 tdv8
Post #655195 30th Jan 2023 9:48pm
pcourtney
PVB1 - was it the firing order cylinder 6, or cylinder 6 position in the engine bay ?
in the diagram below cylinder 1 and 5 are at the front of the engine
Post #655199 30th Jan 2023 10:51pm
pvb1@sky.com
Position in the engine bay. It also plays havoc with the DPF, filling it over a matter of weeks then days. Look at the valve top right.
Post #655214 31st Jan 2023 6:30am
Phoenix
Have you checked the cylinder balances? it may give a clue as to which cylinder needs further investigation (compression test, leakage test etc.)
Post #655219 31st Jan 2023 8:11am
pcourtney
I have similar judder, so am thinking of getting a new Inlet Valve and seeing if it fixes it for £5 quid
https://www.lrparts.net/1311281-inlet-valv...velar.html
Post #655299 31st Jan 2023 10:44pm
Phoenix
You do realise it's a non-trivial repair, don't you?
Post #655301 31st Jan 2023 10:50pm
pcourtney
it does look involved, how many hours would it take for a good indie shop to replace the burnt inlet vale - there may be others on the way out ( or is that unlikely )
Post #655340 1st Feb 2023 12:40pm
kokamagi
Yes it is good idea to do the oil cooler at the same time, because top of the engine must be taken apart anyway.
Also if the valve is really burnt, it is highly possible that the valve seat has to be re-machined, also the head probably will be machined, so it is wise to do other valves as well.
How was the burnt valve diagnosed?
Post #655342 1st Feb 2023 1:16pm
Eugov
United Kingdom 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Interested to see the outcome of this for you? What was it in the end? 2011 Vogue 4.4 TDV8 Orkney Grey
Post #721246 13th Jul 2025 8:42pm
pcourtney
my indie mechanic removed all 8 injectors for me, and we got them tested at Colchester Fuel Injection, really great service and turnaround, 6 injectors were good and tested green ( you get a report for each injector) , but 2 injectors needed replacing, glad to say car has been running fine ever since, thank goodness
https://www.colfuel.co.uk/
at the same time we replaced a lot of other engine related things, like the o-rings on oil pipe, new oil cooler and changed all gaskets on the oil cooler, seemed the right thing to do being 13 years old !
Throttle Body https://www.fullfatrr.com/forum/topic55270.html
MAP and MAF Air Temp Sensors all cleaned up https://www.fullfatrr.com/forum/topic48780.html
It was there for 3 days, had an engine wash and valet at same time, no more judder Smile
Post #721270 14th Jul 2025 5:33pm
Eugov
Interesting….
What sort of cost was that all in? 2011 Vogue 4.4 TDV8 Orkney Grey
Post #721285 14th Jul 2025 7:28pm
pcourtney
£1500 ( and oil change and air filters, usual service items were included I seem to remember )
Post #721286 14th Jul 2025 7:43pm
