![]() | Home > Technical (L322) > Range Rover TDV8 4.4 2011 Won’t Start |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
A lot of those errors come about when the battery is low - what's the voltage showing? 2012 TDV8 Vogue (L322) |
| Rangey1 Member Since: 31 Jul 2021 Location: Wales Posts: 12
Sorry I forgot to mention it’s a brand new battery but is draining very fast too |
What's the voltage showing with the ignition on? 2012 TDV8 Vogue (L322) |
It’s showing 12.6 at the minute but am trying to charge it up too. After a week it goes flat |
12.6 with the charger connected? 2012 TDV8 Vogue (L322) |
The charger is connected |
If the battery is draining and it's not being used it suggests a current leak. Unlike the earlier ones these later cars are very good at shutting everything down once the ignition is off. If it's draining and is being used it suggests an alternator fault but again there is a good monitoring system and it should throw a fault code for this. I'm assuming you fitted the correct AGM battery and used the Icarsoft to update the ECU it has a new battery? 2012 TDV8 Vogue (L322) |
I checked the battery to make sure it’s the right one and used the icarsoft to tell it I’ve changed the battery.
It’s not being used as I can’t get it to start. It was going ok beforehand just intermittent non starting then just wouldn’t start, no crank but switch is ok. |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2784
The terminal block behind the battery has been known to require cleaning and tightening of the nuts. |
| Tdtj Member Since: 29 Sep 2021 Location: East kilbride Posts: 208
Intermittent non starting also points to the starter motor giving up. 2016 4.4 diesel 2019 4.4 diesel |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3350
If you keep the window down or the door open, can you hear a click when you press the button?
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
Sounds like it's wholly a battery / cable issue.
I think the starter motor has died... Do you get any form of click from the starter? Might need to turn the HVAC blowers to off so you can hear... Try several times if you can, foot on brake peddle, and press & hold the starter button...
| All times are GMT |
