Home > Technical (L322) > New version of Microcat - MAY 2011
Page 2 of 3 <123>
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Gazellio wrote:
Thanks Ajay will do Thumbs Up
I normally get that build spec info, and warranty work records, from a LR Main Dealer partner that runs it off their system.
Gaz
This is the actual system that they are using to print your info off.
Matt
Post #64508 18th May 2011 2:06pm
I am having problems extracting data2.cab from the disc I made. It gets to 68% extracted and then stays at 68% although the Disc drive & hard drive lights are still flashing away?
The 68% dialogue box now say not responding...
Gary
Post #64522 18th May 2011 4:55pm
OK guys I now have the system working on my Desktop and can use REG numbers or CHASSIS numbers to pull up data on the cars.
I would like to ask anybody with experience using the system why the data does not load into a printable form even though I have tried several methods I am guessing I am doing something wrong....
All the Data is there in the relevant tabs but I want it on a printable document?
Gaz
Post #64582 18th May 2011 8:59pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Quick question, speaking as somebody new to Microcat and as someone looking to use it to gather more info prior to my first FF purchase - Having entered the reg number of a car how can I find what warranty work has been done (sure I read that can be found using this software)
Also aside from the obvious original spec and trim, what other useful info can be found using this software?
Thanks.
Post #64742 19th May 2011 2:51pm
you cant find out what warranty work has been done on your car via microcat..you can only get this info by contacting a landrover dealer ....
Post #64743 19th May 2011 2:58pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Or not as the case was with me Evil or Very Mad It appears that some dealers will release the warranty information and others wont Confused
Apart from build date and full factory spec Microcat is really only useful to identify the correct part numbers for a specific vehicle Wink
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #64745 19th May 2011 3:04pm
Has anybody worked out how to print the factory spec and other info on the various tabs?
When I select print preview the reg is shown at top but rest of the print page is blank?
Post #64773 19th May 2011 4:04pm
stevecuk
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Windows 7 64 Bit
Anyone managed to get it working with WIN7 X64.
Just tried and when Microlaunch tries to launch mclre it just stops, with no visible window.
Keen to know before I invest a few extra hours building a Virtual XP box?
Thanks
Steve
Post #64815 19th May 2011 6:28pm
I did not use the microlaunch I open my version via the desktop icon created by SETUP that links to C:\MCLRE\mclre.exe
Not sure why the Microlaunch bit was included as it did not work me either and it was not needed anyway Confused
I work on W7 32b
Last edited by Gazellio @ Prestige Cars on 19th May 2011 6:50pm. Edited 1 time in total
Post #64817 19th May 2011 6:35pm
SAppie
Re: Windows 7 64 Bit
Thanks
Steve
Hi Steve, I'm actuall on Win7 x32 Ultimate, and it is working as per the instructions, Haven't tried it on x64 version as yet. Sorry mate!
Post #64820 19th May 2011 6:46pm
stevecuk
Thanks for your replies, looks like the executable is not compatible with X64, and must run on an X86 (32 Bit) system.
Oh well, now to build a new XP Virtual Clone.
Regards,
Steve
Post #64828 19th May 2011 7:19pm
mattstevenson2005
Hi all
In reply to all the Windows 7 issues, i have installed microcat on Windows 7 32bit and it works 100% - i enabled the Windows XP compatibility mode just to be safe and it all worked fine.
In response to the microlaunch comment about it not being need - you DO need microlaunch as microcat works on a monthly licence e.g. April release, May release etc... so once May 2011 ends microcat will stop working without microlaunch. If you dont want to use microlaunch you will need to change your system date to the date you installed microcat to get it working again, microlaunch does this automatically for you when you load the software.
Matt
Post #64909 19th May 2011 10:22pm
Problem is works fine without Microlaunch but does not open with you click the link and nowt happens.....
Post #64921 19th May 2011 10:51pm
mattstevenson2005
not sure what you mean?
Post #64925 19th May 2011 10:53pm
If I click on my icon leading to: C:\MCLRE\mclre.exe - all work fine:
If I click on my icon leading to C:\MCLRE\microlaunch.exe - I get the "MicroLaunch - visit www.lr4X4.com program box come up with link to executable: C:\MCLRE\microlaunch.exe in box and "look for main microcat window" box is ticked.
When I click "OK" nothing much happens.....
Post #64929 19th May 2011 11:00pm
Page 2 of 3 <123>
