![]() | Home > Maintenance & Mods (L322) > Engine cools when coasting |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3310 ![]() ![]() ![]() |
Thermostats are a common fail on these. I've had 2 where the seal has deformed and wrapped around the thermostat causing my cars not to get to operating temperatures. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1394 ![]() ![]() |
Viscous fan issue? |
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 114 ![]() ![]() ![]() |
Afraid not. Range Rover 4.2 SC
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
check if your 4.2 engine has second thermostat on the lower coolant hose. Mine 4.4 ajv8 had this problem, and it was this lower thermostat located in the hose RR HSE 4.4 2006 LPG |
Hi, thanks for your thought. I was told on another forum that it had the other thermostat but after buying a replacement I am now assured by my local garage and Matfords that the SC doesn't have it fitted. . . .
Neither can I, have you trended the actual temperature on a scan tool? Just to check that the transmitter is working OK.. |
Many thanks.
It was indeed the 'secondary' thermostat that had failed - all fixed and thanks for your help. Range Rover 4.2 SC
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 80 ![]() ![]() ![]() |
Incredible and amazing! 2012 Supercharged L322 |
