![]() | Home > Technical (L322) > DCSM Drivers Clim Seat Fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8722 ![]() ![]() ![]() |
An IID tool is a double edged sword, if the seat still works then just leave it alone.... |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
This fault occurs quite frequently just simply when the BCM loses contact, which could be a battery reconnect, seat ECU boots before the BCM, or even an engine start. If everything works and easy entry/exit is all working (which is what the BCM would trigger), then, clear it and ignore it. 2015 Range Rover Autobiography 4.4 SDV8 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 936 ![]() ![]() ![]() |
thank you - have cleared the fault, with engine running and drove over to my Dad's house, 40 mins journey, then came back home and fault has come back |
