![]() | Home > Technical (L322) > How to read Terrain Response data? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8795 ![]() ![]() ![]() |
It will all mean something to someone but if everything is working then don't worry about it....
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
...Its Land Rover...
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 149 ![]() ![]() ![]() |
Yep, IID can read it. I’ll plug in and take a look tomorrow. |
So on the IID tool it reports it in seconds. Here’s mine
Great info! Thanks!
From the 'Ride and Handling Optimization Description and Operation' section on Topix
Time spent in each mode (which will include wake-up & shut-down time) doesn't necessarily include engine running and vehicle moving. It's entirely plausible for Mode 5 to be engaged but only have 1km distance travelled, mode 5 being 'rock crawl'. Also bear in mind that in the main, most have GGS configured to re-engage on next wake-up cycle so the time spent will be higher than actual use. The measurement will be precise, the bounds of the measurement, less so. 55000 hours isn't that much, it's only just over six years (so a well worked 12 year old vehicle or older could have achieved that) and as above, it's 'time spent in mode' so you can pretty much add ~20 mins to every unlock - lock cycle, it's most probably a leftover from the development work that was of interest to determine wear factor variations in each mode, and has no practical application beyond that. |
No, 55000 hours is a lot (if we talking about working hours). 12 year old car and half of that in use??? Are you joking? If drive in 50/50 cycle (city/highway) you should have average speed around 30km/h. 30km x 6 years (ok, lets take 1 year off to get off those 20min) = 1 300 000km.
You can't compare the programming across manufacturers that don't have a single system in common.
I compare the programming across manufacturers due you say 55000h is not that much. 12h per day 24/7 is a lot. Even taxy with multiple drivers cant achieve that amount. That was my thread.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
The quote from the WSM refers to elapsed time which probably includes switched-off time for whatever mode was in use when the ignition was switched off, only terminated when a new mode is selected, either automatically or manually, on the next start-up. |
Interesting, is it possible to read engine working hours from somewhere? |
I wondered that, but it’s not the case as on mine, as has been pointed out, mode 1 is only about 6 years and my car is 11 years old. |
I had a look at mine's distances travelled: mode 2: 359 km, mode 3: 239 km, mode 4: 8 km and mode 5: 144 km.
Yes, seems you are right. Mine the same. |
