![]() | Home > Technical (L322) > 4.4TDV8 FBH - quick question! |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
On my 08 3.6 Vogue, the FBH would run when starting a cold engine if the ambient temp was under 5deg.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7917 ![]() ![]() ![]() |
I believe so. Mine does the same.
Chap on t'Internet is telling me it doesn't, and he's the admin on the 4.4 TDV8 FB page....... |
From the Workshop Manual….
Or the manual…..
Thanks MJ!
Yes, it’s the 4.4 TDV8.
Thanks again MJ!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Must be true then, if he's admin on a FB page ![]() ![]() ![]() ![]() |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
FBH as pre-heater (from fob or timed-climate):
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1312 ![]() ![]() ![]() |
JMC, I don't know whether it's relevant that my car hasn't been started for a few weeks but the last couple of days when starting with a cold engine, the FBH has shrouded my street with a smoke cloud and the outside temperature was about 8-10 degrees.
Smoke mean late ignition. If not use long time its normal at first start. If its continue, burning chamber need to replace (evaporator fault, not serviceble). |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 825 ![]() ![]() |
In very cold conditions ……
