Home > Technical (L322) > Knocking noise on full lock.
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Hello.
While I sit here in the middle of the night looking after my newborn daughter I thought I would ask about a knocking noise I hear from the front of my 2009 TDV8 pre facelift ffrr. It only happens when turning at close too or full lock, 1 or 2 loud and deliberate clunking/knocking noises.
Guessing something is worn or has failed but it doesn’t seem to affect the ride or handling when driving normally.
Will get it checked out but would like to know the possibilities for now, even read it could be something to do with bolts not being tight enough but I find that a little odd!
Any suggestions welcome, hoping it’s not a major issue and just a service item of sorts.
Post #645544 14th Oct 2022 2:49am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
The PAS pipes can knock when held on full lock as it's overloading the pump.
If it were the tie rods it would do it all the time. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #645565 14th Oct 2022 10:55am
KitTheRam
Would that happen only when on full lock? It can happen at a few different points when turning the wheel from memory but defo more when closer to full lock.
It’s quite a loud sound.
Post #645566 14th Oct 2022 11:10am
KitTheRam
Tightened a bolt on the control arm that appeared to be slightly loose but still a load knocking noise on or near full lock (mainly when turning right). The search goes on as all looks good and quite new in every aspect of the front suspension.
Post #646170 21st Oct 2022 11:45pm
Could be from a lot of places, drop links are always a popular source, you can disconnect one, move it out the way and try it, if noting else it will eliminate the drop link and ARB bushes... Thumbs Up Pete
Post #646181 22nd Oct 2022 8:25am
KitTheRam
Good advice. Thanks.
Post #646189 22nd Oct 2022 9:45am
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
I assume you have tried the CV joints for play? The outer will knock on full lock when turning at low speed under power. MOT failure too.
Post #646225 22nd Oct 2022 7:48pm
KitTheRam
I think they are ok (everything we looked at looked ok!). But will check again.
Post #646230 22nd Oct 2022 8:18pm
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Not sure if they’re a similar set up to a D4 but could be the steering lock stops on the lower arms a drop of grease normally helps
Post #646332 23rd Oct 2022 8:59pm
KitTheRam
Had the car looked at again and the drivers side front lower arm subframe bolt was loose, was missed in the first inspection somehow. Replaced the bolt and nut (both oem) to the correct nm and the knock has gone. Not sure what was wrong with the previous bolt to stop it tightening correctly, guessing it’s original so quite old but the bolt itself looks fine, the nut was quite rusty so perhaps the culprit. Will clean up the bolt and put it in my spares box. 2009 pre-facelift 3.6 TDV8.
Post #648828 22nd Nov 2022 2:04am
