Home > Technical (L322) > Puddle light options.
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Hello.
My puddle light bulbs have gone, looking to replace.
Thoughts on standard bulbs v LED bulbs v LED plug and play units?
Worry that the aftermarket LED units will be too bright, don’t mind the subtle glow of the originals but maybe a little brighter would be nice. Guess there is no soft-white LED option or a brighter standard bulb?!
Has anyone used these? https://www.halfords.com/motoring/bulbs/50...OmEALw_wcB
Post #646231 22nd Oct 2022 8:23pm
garyRR
The puddle lights are Canbus monitored. When I tried Halfords 'error free' LED bulbs as my side lights in my old 3.6, it still threw an error on the dash so, they may do the same in the puddle lights.
This is the guide I wrote for all things LED:
https://www.fullfatrr.com/forum/topic62660.html 2015 Range Rover Autobiography 4.4 SDV8
Post #646238 22nd Oct 2022 9:17pm
I bought some off eBay with some little projector logos in them. Dead easy fit and look a bit different when you open the door. Think they projectors a white circle with Range Rover in it…. But it’s a while ago now. There is nothing that can't be fixed with a hammer😜😜
Post #646241 22nd Oct 2022 9:30pm
KitTheRam
Thanks.
GaryRR - out of interest what brand of led mirror puddle light units did you buy?
All the ones I have found look like the ones ‘powerful uk’ sell, I’m new to Land Rovers and not sure what to think of those guys…
Post #646243 22nd Oct 2022 9:45pm
KitTheRam
After reading your guide I’m I right in thinking these should not be a problem once fitted?
https://www.hids-direct.co.uk/philips-x-tr...fWEALw_wcB
(Sorry, just noted that these are interior only…)
May just stick to standard for now!
Post #646245 22nd Oct 2022 9:52pm
garyRR
Generally they sell ok stuff but some of it is the same stuff available everywhere else with a massive markup on.
I would steer clear of the LED bulbs they sell - I've seen them on a Chinese wholesale site for 25p a bulb and they do not have good reviews.
Your best bet is Philips, Ring or Osram for non-Canbus. For Canbus monitored, you're best with retrofits - they're cheap enough to replace if they do fail. 2015 Range Rover Autobiography 4.4 SDV8
Post #646246 22nd Oct 2022 9:53pm
garyRR
All LED bulbs say interior only because technically, LED bulbs in driving lamps designed for incandescent bulbs are an MOT failure. However driving lamps are regarded as headlights, brakes, indicators, side lights, main beam and reverse obviously.
They're fine to use in comfort lighting such as mirror puddles. But those bulbs linked aren't Canbus error free. 2015 Range Rover Autobiography 4.4 SDV8
Post #646247 22nd Oct 2022 9:56pm
KitTheRam
Thanks. Impressively comprehensive and useful lighting guide you wrote there.
Post #646248 22nd Oct 2022 9:57pm
KitTheRam
For anyone looking I found these canbus error free 501’s.
https://www.ebay.co.uk/itm/174461271316?mk...media=COPY
Post #646250 22nd Oct 2022 10:13pm
Let us know if they work OK, there are a lot of "error free" bulbs out there that don't live up to their name... Pete
Post #646264 23rd Oct 2022 8:20am
Phoenix
The 'CANBus' bit is a misnomer as well, all the lamps have to do is to draw enough current to prevent the lamp failure monitoring in the control module from signalling a defect, so theoretically with the application of Ohm's law and a soldering iron, you could make your own 'error free' LED lights, I suspect most of the failures are due to relatively high power resistors being encapsulated in small packages with little chance of airflow to dissipate the heat generated, personally, I'd mount the dummy load resistors somewhere else in the circuit with a bit of space around them.
Post #646282 23rd Oct 2022 10:14am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
I buy those, together whit full interior lights.
https://www.aliexpress.com/item/4001149623...pt=glo2idn
Post #646289 23rd Oct 2022 11:41am
KitTheRam
Decided that the LED options will be too bright for my needs, so plumped for these.
Should be brighter but not too bright! https://www.ebay.co.uk/itm/333738719530?mk...media=COPY
Post #646294 23rd Oct 2022 12:54pm
