Home > Technical (L322) > Alternator diagnostics |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Forget charge rate for now, look at quiescent / parasitic current drain. anything more than 50mA (thats 0.05A) is a problem, and really anything consistently over 40mA should be investigated. |
23rd Oct 2022 2:09pm |
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 |
Looks like i need to buy a current clamp then, any recommendations?
23rd Oct 2022 3:41pm |
Yep, don't bother - the consumer ones are not great for low current as they tend to give false readings after an hour or more, if you have a multimeter with a proper Amps setting, use that, oh, make sure it has fresh batteries, a peak reading hold setting and a way to disable auto power-off.
23rd Oct 2022 4:34pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Don't forget some sponsor Glenrands up the A3 in Passfield if you need a great local independent specialist Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Oct 2022 5:06pm |
An update,
24th Oct 2022 4:47pm |
What is the resolution of your current clamp? As I mentioned, 50mA is the upper limit, you need to look at peak and quiescent current draw over a number of hours - remembering that the EAS will 'wake up' to do a periodic level check & correction, it's not a quick job to do properly. |
24th Oct 2022 4:58pm |
The unit claims 0.001 amps on the clamp but I doubt it can. I suspect its more like 0.01.
24th Oct 2022 6:31pm |
A 10mA resolution isn't great when one digit out can put you under or over the 'there's a fault' threshold, my own clamp meters have a resolution of 1mA DC across different scales but TBH I still prefer to use direct measurement for anything lower than 500mA, mainly due to the amount of electrical noise that can be picked up and lead you down entirely the wrong rabbit hole....
24th Oct 2022 7:14pm |
Thanks for that, not sure how you measure the voltage drop as you would have to be in the car with it locked and internal motion alarm disabled. Also from memory the blade fuses stop you accessing the slots when they are fitted. it might be easier to pull the fuse and measure current across contacts with a meter. L322 4,4 TDV8
24th Oct 2022 7:22pm |
Push the door latches across so it thinks the doors are closed and use the key functionality to lock without interior protection, you measure the mV across the fuses with them in place to determine the volt drop across the fuse (by virtue of it's resistance) and use the tables to give an indication of current flow. Don't go pulling fuses as that will in most cases 'wake up' various modules and lead you down entirely the wrong path.
24th Oct 2022 7:45pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1364 |
Just circling back to the battery point.
24th Oct 2022 10:53pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Alternators have a common habit of discharging the battery so could be at fault so a replaement may solve both charging and discharging problems. |
25th Oct 2022 8:58am |
Alternator rectifier pack failure is not what i'd call 'common' - and would be certainly draw more than the 0.05A that is being measured. Alternator diodes only convert AC to DC, it's the regulator pack (commanded by the ECM) that controls the output voltage.
25th Oct 2022 9:52am |
Morning update,
25th Oct 2022 9:55am |
