Home > Technical (L405) > Bonnet catches
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Bonnet catches
I’ve checked the previous posts, but I none relate to L405.
I hate slamming the bonnet Down but the near side catch won’t grab otherwise. Had it all apart looking for an adjustment, but can’t find any. Any ideas please. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #646307 23rd Oct 2022 3:42pm
harisson
Switzerland
same here, on a MY2022 L494 (Sport)
my car has the guarantee and so it will go to the dealer to get a new lock / catch on the right hand side (in driving direction).
The hood will also be aligned (again)
I don't know if there is any possibility to solve it without exchanging the lock/catch Range Rover Sport HST D350
Post #646358 24th Oct 2022 12:17pm
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I’m in the same boat and have just got used to it - agree it seems odd. Mine is just on one side too. 2016 SDV8 AB
Post #646361 24th Oct 2022 1:18pm
rainking
Mine is the same, but only on one side... I'd say it seems very odd... but it's a Range Rover.... stupid idiosyncratic nonsense is kind of it's thing Andrew.
Post #646364 24th Oct 2022 1:41pm
TJH1985
Same here, complained 3/4 times to the dealer and even picked it up once with the catch not caught properly and they still didn't do much about it. LR Assist once stripped it on my drive and found nothing much wrong, it was a little better after that.
In the end I just accepted "They all do that Sir, you need to give it a slam" Neutral Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #646385 24th Oct 2022 4:16pm
...and same here. Its just the nearside on mine and makes me wince when I have to slam it. Mike - MPx
Post #646409 24th Oct 2022 7:34pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Same, nearside…
Post #646426 24th Oct 2022 8:26pm
fisha
I’ll be the odd ball …. Offside for me! Don’t need to slam it though, just a firm press down as it closes. Doing it gently, then only the near side bites properly. V8 or else ...
Post #647121 2nd Nov 2022 9:10am
Fifth Horseman
Nearside one has been the problem for me, but more with the switch for the alarm. The first time the catch failed to latch I found the supplying dealer had bypassed the switch to stop the alarm going off.. Evil or Very Mad
There is adjustment for the position of the catch - the mounting holes are oversized so the catch can be moved to the best position. Also the rubber bump stops on the corners of the bonnet are adjustable.
Post #647184 3rd Nov 2022 9:09am
theres a rumour that the bloke who was fitting the bonnet catches in the factory in solihull got fired after a couple of years cos he only had one eye so could only adjust one side properly...
mines the same ,offside.. Thumbs Up ... - .- -.
Post #647186 3rd Nov 2022 9:49am
Bill
Ditto.
Oddball club for the off side 405’s Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #647199 3rd Nov 2022 12:56pm
TJH1985
Ours is also offside Rolling with laughter
LR Assist spent about 2 hours on it, I have no interest in spending any more time so I’ll just be firm with it Thumbs Up Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #647200 3rd Nov 2022 1:05pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Mine needs a slam too, right side...
Post #647202 3rd Nov 2022 2:04pm
To adjust the bonnet you adjust the latch position... Held on with torx bolts... Thumbs Up
Post #647207 3rd Nov 2022 3:39pm
swissomatic
United States 2015 Range Rover 5.0 SC V8 Fuji White
Not sure if I am correct but a lot of cars have only one catch so it's not as sensitive to adjustment. Opened mine up on day 5 of ownership, adjusted both sides, greased catches and springs with fine mist of synthetic gun oil and seven years later still closes properly with little extra nudge every time. The rubber noise seals and plastic grommets spread throughout the engine compartment are a whole other discussion. Should have sign which says dispose after one try.
Post #647220 3rd Nov 2022 5:08pm
