Home > Maintenance & Mods (L322) > Holding 4th gear…
Danwilderspin
Holding 4th gear…
Hi all I’ve notice today even when the car is up to temperature it’s going smoothly into gears as expected but stops at fourth and I was going downhill feathering the loud peddle over 3000rpm and it would not go into 5th - if I pull the paddle it goes to 5th and 6th no issue and stays there…
Any ideas it did it all the way in an hour drive this morning? No faults Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #646783 29th Oct 2022 12:50pm
JayGee
Depending on how steep the hill is it will hold gears to control speed. 2012 TDV8 Vogue (L322)
Post #646787 29th Oct 2022 1:39pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Yes, that is normal. I have the same, mine keept 6th and 7th quite long, up to 10km. It depends of gearbox temp., not the engine.
Post #646814 29th Oct 2022 9:18pm
Danwilderspin
I found the issue looks like my tyre monitor isn’t working I was driving around with 12psi in the passenger tyre 🤦‍♂️ it took air and was fine think I will take to the garage to check I’ve not wrecked it next week though Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #646819 29th Oct 2022 10:13pm
