Home > Maintenance & Mods (L322) > Incorrect working PDC sensor without a fault
Eventer
Germany 2002 Range Rover Vogue 4.4 V8 Epsom Green
I checked each sensor. Everthing is okay. There is no fault but a right sensor thinks there is a obstacle. What can I do?
Post #647082 1st Nov 2022 6:34pm
Phoenix
Swap the suspect one with another, if the incorrect detection moves, then its a faulty sensor, if it stays at the same position, then either the harness or the module.
Post #647097 1st Nov 2022 9:10pm
Eventer
Hello and thank you for your prompt reply. I already bought a new one and changed each one to the new. It stays. Is there a seperate module for PDC in a 2002 L322? Where is it?
Post #647116 2nd Nov 2022 7:33am
Most likely the wiring harness for the sensors, well known failure point.... Thumbs Up Pete
-Click here for Thread-
Post #647127 2nd Nov 2022 11:06am
