![]() | Home > Technical (L322) > 3.6 TDV8 Running Lumpy/Missing & Smoking |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3312 ![]() ![]() ![]() |
The wave routine in the picture was peaking and troughing as the throttle was being blipped. If I held the revs stationary the commanded position went to a flat line as per the end of the graphs. It did the same but at a different position if I let it idle. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Ah right - this is actual values not the ECM's interpretation. You can see the 'unstick' activity.
Interesting.
Well there's two separate fresh and charge air paths but they both end up being shared across the plenum,
Thanks Phoenix,
Been doing some reading tonight and have found these 2 threads which are a huge help:
Pleased to report I managed to find the passengers side actuator. You need to look through this oval hole:
Excellent!
Thanks Phoenix.
Fresh oil, heat and use are the best reconditioners for engines, I've seen a few rebuilt engines from various 'classic' (i.e. old and mostly unloved) cars rebuilt at great expense, then parked up and ignored for 11.5 months, then suddenly expected to perform like a daily workhorse, with predictable results.
